电子发烧友论坛|
我重新生成了11.2012购买的ISE Logic Edition的许可证文件。
如果我理解正确,这应该涵盖高达14.7的ISE版本。 我将此生成的许可证文件加载到许可证管理器中:我收到“许可证安装成功”的信息,但两者都显示在“管理许可证”选项卡下:未列出任何功能。 你能解释一下发生了什么吗 为什么没有从许可证文件中提取产品? 服务器名称和NIC ID正确并反映文件中的内容。 任何想法? 问候 WOJTEK 以上来自于谷歌翻译 以下为原文 I regenerated the license file for ISE Logic Edition purchased in 11.2012. This should cover ISE releases up to 14.7, if I understand it correctly. I loaded this generated license file into License Manager: I get the info that "License Installation was successful" but bothing appears under "Manage Licenses" Tab: no feature listed. Could you explain what happened? Why no product is extracted from license file? Server name and NIC ID are correct and reflects what is in file. Any idea? Regards Wojtek |
13个回答
你好@wojtek
由于您拥有浮动许可证,请按照以下步骤安装此许可证。 1.从此处下载许可证管理工具 2.解压缩下载文件并将许可证(Xilinx-ISE_Design_Edition_start_11_2012.lic)复制到解压缩的文件夹 3.打开命令提示符并导航到解压缩的文件夹。 4.运行以下命令:lmgrd -c Xilinx-ISE_Design_Edition_start_11_2012.lic -l debug.log 5.现在打开Xilinx许可证配置管理器并将XILINXD_LICENSE_FILE设置为2100 @ pc-wj2 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hello @wojtek Since you have a floating license, follow below steps to install this license. 1. Download license management tools from here 2. Unzip the download file and copy the license (Xilinx-ISE_Design_Edition_start_11_2012.lic) to the unzipped folder 3. Open command prompt and navigate to the unzipped folder. 4. Run the following command: lmgrd -c Xilinx-ISE_Design_Edition_start_11_2012.lic -l debug.log 5. Now open Xilinx License Configuration Manager and set XILINXD_LICENSE_FILE to 2100@pc-wj2 Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution.View solution in original post |
你好@ WOJTEK,
许可证涵盖的ISE设计套件版本取决于许可证文件中的版本限制。 您可以查看以下AR以获取详细信息 http://www.xilinx.com/support/answers/33770.html 你能在这里附上你的许可证文件和xinfo文件,以了解问题的原因吗? 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @wojtek, The ISE design suite version covered by your license depends on the version limit persent in license file. You can check below AR for details http://www.xilinx.com/support/answers/33770.html Can you attach your license file and xinfo file here to know cause of problem? Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
xinfo.txt中可能有用的信息如下:
主机名:pc-wj2Network接口卡ID:001372e4442a XILINX:C: Xilinx 14.7 ISE_DS common ; C: Xilinx 14.7 ISE_DS ISE *许可证信息:无可用的xilinxd功能信息C:/。Xilinx Xilinx-ISE_Design_Edition_start_11_2012.lic 00007 但在“Xilinx-ISE_Design_Edition_start_11_2012.lic”文件中,我有以下内容: SERVER pc-wj2 001372e4442a 2100 INCREMENT Logic_Edition xilinxd 2013.11永久1 ...... PACKAGE Logic_Edition xilinxd 2013.11 ....... COMPONENTS =“SDK ChipScopePro_SIOTK ChipscopePro ISE ISIM PlanAhead XPS XC7Z010 XC7Z020 XC7Z030 XC7Z045模拟实现分析器HLS 综合”选项=套件 这些信息有助于得出任何结论吗? 以上来自于谷歌翻译 以下为原文 The info from xinfo.txt which could be usefull is as follow: Hostname: pc-wj2 Network Interface Card ID: 001372e4442a XILINX: C:Xilinx14.7ISE_DScommon;C:Xilinx14.7ISE_DSISE * License Information: No xilinxd Feature Information Available C:/.XilinxXilinx-ISE_Design_Edition_start_11_2012.lic 00007 But in the "Xilinx-ISE_Design_Edition_start_11_2012.lic" file I have the following: SERVER pc-wj2 001372e4442a 2100 INCREMENT Logic_Edition xilinxd 2013.11 permanent 1 ...... PACKAGE Logic_Edition xilinxd 2013.11 ....... COMPONENTS="SDK ChipScopePro_SIOTK ChipscopePro ISE ISIM PlanAhead XPS XC7Z010 XC7Z020 XC7Z030 XC7Z045 Simulation Implementation Analyzer HLS Synthesis" OPTIONS=SUITE Would this info help to draw any conclusion? |
我写道,我做到了:虽然许可证文件已成功加载,但没有功能适用
以上来自于谷歌翻译 以下为原文 I wrote I did it: no feature apppears although License file loaded successfully |
嗨@ WOJTEK,
你可以重启ISE,看看许可证是否正常运行? 谢谢,Nupur 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @wojtek, Can you please restart ISE and see if the license is working fine? Thanks, Nupur Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
你好@ WOJTEK,
由于您使用的许可证是浮动许可证,因此在服务器计算机上成功安装许可证之后,您需要将客户端计算机上的XILINXD_LICENSE_FILE变量(您要在其中使用许可证文件中的功能)指向@。 您可以尝试指向此变量,如下面的快照所示,让我们知道它是否有所作为? 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @wojtek, Since the license which you are using is floating license, you need to point XILINXD_LICENSE_FILE variable on the client machine (where you want to use the features in license file) to Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
我原创(2100 @ pc-wj2),但在尝试时将其删除,如果它对我的问题有帮助。
现在我将其添加回来,它出现在许可证管理器窗口中,我加载了许可证文件,但即使在重新启动后也没有出现功能。 以上来自于谷歌翻译 以下为原文 I had it originaly (2100@pc-wj2) but removed it when trying if it would help in my problem. Now I added it back, it appears in the License Manager window, I loaded the license file, but no Feature appears, even after restart. |
你好@wojtek
由于您拥有浮动许可证,请按照以下步骤安装此许可证。 1.从此处下载许可证管理工具 2.解压缩下载文件并将许可证(Xilinx-ISE_Design_Edition_start_11_2012.lic)复制到解压缩的文件夹 3.打开命令提示符并导航到解压缩的文件夹。 4.运行以下命令:lmgrd -c Xilinx-ISE_Design_Edition_start_11_2012.lic -l debug.log 5.现在打开Xilinx许可证配置管理器并将XILINXD_LICENSE_FILE设置为2100 @ pc-wj2 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @wojtek Since you have a floating license, follow below steps to install this license. 1. Download license management tools from here 2. Unzip the download file and copy the license (Xilinx-ISE_Design_Edition_start_11_2012.lic) to the unzipped folder 3. Open command prompt and navigate to the unzipped folder. 4. Run the following command: lmgrd -c Xilinx-ISE_Design_Edition_start_11_2012.lic -l debug.log 5. Now open Xilinx License Configuration Manager and set XILINXD_LICENSE_FILE to 2100@pc-wj2 Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
Vuppala,您的步骤确实有所帮助:在运行lmgrd之后,我打开了Xilinx许可证配置管理器,并且许可证涵盖了所有ISE功能。
非常感谢你!!! 我只是很好奇,Xilinx许可证配置管理器无法完成这项工作的原因是什么以及为什么lmgrd有帮助? 以上来自于谷歌翻译 以下为原文 Vuppala, your steps really helped: after I run lmgrd I opened Xilinx License Configuration Manager and all ISE features covered by the license were available there. Thank you very much!!! I'm just curious, what was the reason the Xilinx License Configuration Manager couldn't do the job and why lmgrd helped? |
您好@wojtek原因是:您有浮动许可证。您不应直接在Xilinx许可证配置管理器中加载浮动许可证。谢谢,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @wojtek The reason is: You have floating license. You should not load floating license directly in Xilinx License Configuration Manager. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
@vuppala:每次重启电脑后我都要运行lmgrd吗?
以上来自于谷歌翻译 以下为原文 @vuppala : do I have to run lmgrd every time after rebooting computer? |
你好@wojtekNot必需。
您可以在启动程序中添加此lmgrd服务,这样每当您重新启动系统时,它将启动lmgrd服务。谢谢,Vinay -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hello @wojtek Not required. You can add this lmgrd service in startup programs so that whenever you reboot the system, it will start the lmgrd service. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1198浏览 1评论
/9
GMT+8, 2025-12-14 07:37 , Processed in 1.021614 second(s), Total 95, Slave 78 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1874
