电子发烧友论坛|
我最近购买了一个8596E,它在0频段完美无缺。在1频段转换时,可以看到额外的27dB损耗。
我已经输入了一个在2.9GHz和3.0GHz之间切换的信号源,它位于0和1频段。频段0幅度点亮,而频段1幅度低27dB。 在梳状信号中可以看到相同的结果。 这是奇怪的事情(但缺乏内部校准的知识)。 如果我运行YTF校准,当梳子的每个支线用于校准时,校准波形在频率进入频段1时显示NO下降。这怎么可能? 由于cal使用实际的分析仪输入,不会排除SYTF或混频器的问题吗? 什么会导致这种巨大的衰减出现在实际使用中,但不会出现在cal中。 该单位偶尔无法完成YTF校准,大多数时候混合器偏置校准失败,无疑是由于此频段1丢失。 谢谢你能解决这个问题。 巢穴 以上来自于谷歌翻译 以下为原文 I recently acquired an 8596E which performs flawlessly in band 0. At the band 1 transition, an additional loss of 27dB is seen. I've fed in a source toggling between 2.9GHz and 3.0GHz which is in band 0 and 1. The band 0 amplitude is spot on while the band 1 amplitude is 27dB down. The same can be seen in the comb signal. Here's the odd thing (lacking knowledge of the internal cal, however). If I run the YTF cal, as each spur of the comb is used for the cal, the cal waveform shows NO drop as the frequency enters band 1. How can this be? Since the cal uses the actual analyzer input, wouldn't that rule out the SYTF or mixer as problems? What would cause this huge attenuation to appear in actual use but not in cal. The unit occasionally cannot complete YTF cal and most times fails mixer bias cal, no doubt due to this band 1 loss. Thank you for any light you can shed on this problem. Den |
1个回答
更多信息......我发现100MHz梳子关闭了600Hz(规格是+/- 40)所以我调整到几赫兹以内。
这没有任何区别,因为该装置仍然存在YTF校准和混频器偏置校准问题,均在11-12 GHz附近。 看起来如果2.9xx GHz的27dB损失消失了,这些cals就会全部通过。 当您运行YTF校准时,屏幕下边缘的“电量计”(我认为与YTF上的驱动电平有关)一直到11-12 GHz区域的屏幕中心。 所以问题仍然存在...... 27dB损失的原因是什么?为什么当你观察YTF cal进展时这不显示? 巢穴 以上来自于谷歌翻译 以下为原文 More info ... I discovered that the 100MHz comb was off by 600Hz (spec is +/- 40) so I adjusted to within a few Hz. This made no difference as the unit still had a problem with YTF cal and Mixer Bias cal, both near 11 - 12 GHz. It looks like if the 27dB of loss at 2.9xx GHz went away, these cals would all pass. When you run the YTF cal, the "gas gauge" at the screen lower edge, which I presume is related to the drive level on the YTF, goes all the way to screen center at the 11 - 12 GHz region. So the problem remains ... what is the cause of the 27dB loss and why doesn't this show when you watch the YTF cal progress? Den |
只有小组成员才能发言,加入小组>>
263 浏览 0 评论
1863 浏览 0 评论
2755 浏览 1 评论
2657 浏览 1 评论
2477 浏览 5 评论
1863浏览 0评论
433浏览 0评论
263浏览 0评论
/9
GMT+8, 2025-12-12 17:14 , Processed in 0.796319 second(s), Total 71, Slave 54 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1267
