电子发烧友论坛|
当我完成将我的8596E精密基准调整到精确10MHz(通过ref-out和铷参考之间的时间差)时,当10MHz的跟踪发生器输出(零跨度)为10.02 MHz时,我的气泡爆裂。
我本可以发誓,我的旧E4401A(1.5GHz分析仪)是“点亮”并且天真地认为跟踪发生器已合成并锁定到参考。 我在另一个论坛上被用户告知TG可能由LO驱动,我也注意到对RBW的依赖。 感觉不好,我查看了许多HP / Agilent分析仪(85xx,ESA,PSA)的漂移规格,大多数情况下,它在5分钟内达到1.5kHz。 现在我感觉不是很糟糕,但TG不会成为我的精确来源(便宜的一面)。 如果有人能描述零跨度时的频率精度与影响它的其他SA参数之间的关系,那将是一个很大的帮助。 我意识到跟踪调整功能可能适用于大多数预期用途。 谢谢,Den 以上来自于谷歌翻译 以下为原文 As I finished adjusting my 8596E precision reference to precisely 10MHz (via time delta between ref-out and a rubidium reference), my bubble was burst when the tracking generator output (in zero span) at 10MHz was 10.02 something MHz. I could have sworn that my old E4401A (1.5GHz analyzer) was "spot on" and naively assumed that the tracking generator was synthesized and locked to the reference. I've been informed by users on another forum that the TG may be driven by the LO and I've also noticed dependency on RBW. Feeling bad, I looked through drift specs on many HP / Agilent analyzers (85xx, ESA, PSA) and for the most part, it is 1.5kHz in 5 minutes. Now I don't feel so bad but the TG is not going to be a precise source for me (being on the cheap side). It would be a big help if someone could describe the relationship between the frequency accuracy when in zero span, and the other SA parameters which impact this. I realize that the tracking adjusment function probably is adequate for most intended uses. Thanks, Den |
2个回答
谢谢你的解释和图表。 为了将来参考,ESA和PSA系列跟踪发生器是否完全合成并独立于第一个LO? 我注意到所有系列,无论新旧,似乎都有相同的漂移规格。 此致,Den 以上来自于谷歌翻译 以下为原文 Thank you for the explanation and diagram. For future reference, are the ESA and PSA series tracking generators fully synthesized and independent of the 1st LO? I noticed that all series, old and new, seem to have the same drift spec. Regards, Den |
nvywyrww 发表于 2018-11-28 19:02 对于ESA系列,E4401B,E4411A,E4411B具有合成跟踪发生器,并且与第一个LO分开,而其余的则没有。 这意味着1.5 GHz跟踪发生器是合成的,3 GHz跟踪发生器不合成。 PSA系列没有跟踪发生器选项。 最好的问候,迈克 以上来自于谷歌翻译 以下为原文 For the ESA series, the E4401B, E4411A, E4411B have synthesized tracking generators and are seperate from the 1st LO while the rest are not. What this means is that the 1.5 GHz tracking generators are synthesized and the 3 GHz ones are not. The PSA series does not have a tracking generator option. Best regards, Mike |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 08:41 , Processed in 0.543554 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1600
