电子发烧友论坛|
大家好,我有一个PSA E4440A似乎有一个问题,用预选器纠正。
这会影响3GHz以上的所有输入。 例如,我输入5GHz @ -10dBm。 无论我的跨度设置如何,我都可以看出振幅读数很低,约为-35dBm。 我将频率居中,并将跨度减小到20MHz。 标记读数为5.000000,幅度为-35dBm。 如果我点击Presel中心,信号会跳到-10到-11之间。 右侧菜单上的Presel Adjust显示47.80MHz,之前读取0Hz。 每次改变频率时我都要经历这个例行程序。 从我在手册中阅读的内容和论坛上看,可能会出现1或2dB的偏移,而不是我得到的25dB。 我错了。 我有两个仪器正在执行此操作,第三个正常运行,在击中Presel Center之前振幅非常接近,按下它后变化不大。 所以我的问题是,如果有人知道这是一个关闭的设置,可能在工厂预设中丢失的校准常数,可以通过TME软件调整修复的调整,还是硬件故障? 谢谢,迈克 以上来自于谷歌翻译 以下为原文 Hi everyone, I have a PSA E4440A that appears to have a problem that is corrected with the preselector. This affects all inputs over 3GHz. As an example, I input 5GHz @ -10dBm. Regardless of what I have the span set to, I can tell that the amplitude is reading low, around -35dBm. I center the frequency, and reduce the span to 20MHz. The marker reads 5.000000, with an amplitude of -35dBm. If I hit the Presel Center, the signal jumps up to between -10 and -11 where it should be. The Presel Adjust on the right side menu shows 47.80MHz, where as before it read 0Hz. I have to go through this routine every time I change frequency. From what I read in the manual, and here on the forum, 1 or 2dB of shift might be expected, not the 25dB that I’m getting. I could be wrong. I have two instruments that are doing this, and a 3rd that acts as normal, the amplitude is pretty close before hitting the Presel Center, and doesn’t change much after pressing it. So my question is if anyone knows whether this is a setting that got switched off, cal constants that might have been lost in a factory preset, an adjustment that can be fixed with a TME software adjustment, or if it is a hardware fault? Thanks, Mike |
4个回答
迈克,你的问题很常见。
RHYTHM组件的滤波器部分的粗略偏移和增益调整设置不对齐。 这些单元需要对齐和新校准,以纠正此问题。 这可以通过Agilent TME软件N7800A完成,即如果您有一个校准实验室,可以正确校准并具有正确的校准标准。 或者,您需要发送到安捷伦进行校准,为此,这种校准将包含在平率校准电荷下。 以上来自于谷歌翻译 以下为原文 Mike, Your problem is common. The coarse offset and gain adjustment settings for the Filter part of the RHYTHM assembly is out of alignment. The units require alignment and a fresh calibration which should correct this problem. This can be done with Agilent TME software N7800A, that is if you have a calibration lab that can do the calibration correctly and has the correct calibration standards. Or, you will need to send into Agilent for calibration, for which, this alignment would be covered under the flat rate calibration charge. |
谢谢你的回复,这让我的生活变得更加简单。
我们仍然在等待采购获得许可证,但我不希望两个SA坐在一起,如果调整不能解决它们。 以上来自于谷歌翻译 以下为原文 Thanks for the reply, this makes my life simpler. We’re still waiting for procurement to get the license, but I didn’t want both SA sitting around if the adjustments wouldn’t fix them. |
嗨迈克 - 每当YTF预选器的默认居中关闭超过其带宽的一半时,您可以预期在预选器居中之前测量信号是低的。 YTF预选器的带宽在3 GHz时约为30 MHz,在26.5 GHz时增加到约60 MHz。 因此,如果预选器在3 GHz时的频率超过15 MHz,您将看到滤波器边缘的效果会使信号衰减。 修复是在TME校准软件中运行YTF调整。 另外,为了更好地测量,建议从YTF清洁带状电缆的触点,它连接到前端驱动器组件。 YTF的驱动阻抗非常低,因此任何导致电缆触点电阻略微增加的腐蚀都会导致YTF漂移。 问候 - 以上来自于谷歌翻译 以下为原文 Hi Mike - Whenever the default centering of the YTF preselector is off by more than half its bandwidth, you can expect the measured signal to be low prior to preselector centering. The bandwidth of the YTF preselector is about 30 MHz at 3 GHz and increases to about 60 MHz at 26.5 GHz. Therefore, if the preselector is of by more than 15 MHz at 3 GHz, you will see the effect of the skirt of the filter attenuating the signal. The fix is to run the YTF adjustment in the TME calibration software. Also, for good measure it is recommended to clean the contacts of the ribbon cable from the YTF where it connects to the front end driver assembly. The drive impedance is quite low for the YTF, so any corrosion that causes any slight increase in resistance at the contacts of the cable can cause the YTF to drift. Regards - |
醉狼工作室 发表于 2019-3-18 17:59 您好Tabbott,感谢您的回复,以及清洁连接器的提示。 麦克风 以上来自于谷歌翻译 以下为原文 Hi Tabbott, Thanks for the reply, and also for the tip on cleaning the connector. Mike |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 10:58 , Processed in 0.775184 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1497
