电子发烧友论坛|
我们的WiFi的设计使用了MurATA LBEH5HZZPC部件,使用CyPress CYW433
我们无法获得WiFi部分的操作,直到我们添加了一个外部的32 kHz时钟到引脚36(LPOIIN)。 根据CYW433 9数据表,该设备使用一个32 kHz的时钟来控制功率排序,这可以是内部振荡器或外部振荡器。 我们期望使用内部振荡器,但不能确定如何使其工作。添加外部振荡器允许部件正确工作。 LBEH5HMZPC数据表并没有明确规定在任何外部振荡器都需要的地方,但是每一个图都显示LPO作为外部输入。 CyPress CYW433数据表并没有告诉我们如何从内部LPO强制操作,而不是外部LPO输入。 LBEH5HZZPC是否可以使用内部LPO操作,如果是这样,我们如何强制这种操作模式? 在LBEH5HMZPC中使用的TCXO参考频率是多少? 这是用于MLATA LBEH5HMZPC数据表中推荐的LFB182G45 SG9A22过滤器的数据吗? 我们在哪里得到最新的固件为LBEH5HZZPC,它由Linux驱动程序加载(FWYBCMDHD.bin,FWYBCMDHDYAPSTA.bin和FWYBCMDHDYMFGTest.bin)。 我能知道在哪里可以找到CYW433 9固件的最新版本吗? 谢谢! 郝 以上来自于百度翻译 以下为原文 The design for our WiFi uses the Murata LBEH5HMZPC part which uses a Cypress CYW4339 We were not able to get the WiFi part operating until we added an external 32kHz clock to pin 36 (LPO_IN). According to the CYW4339 datasheet the device uses a 32kHz clock to control power sequencing. This can either be the internal oscillator or an external oscillator. We were expecting to use the internal oscillator but cannot determine how to make it operate. Adding the external oscillator allows the part to operate correctly. The LBEH5HMZPC datasheet does not specifically state anywhere that an external oscillator is required but every diagram shows the LPO as an external input. The Cypress CYW4339 datasheet does not tell us how to force operation from the internal LPO instead of the external LPO input. Is it possible for the LBEH5HMZPC to operate using the internal LPO and if so how we force this mode of operation? What is the TCXO reference frequency used in the LBEH5HMZPC? Is this data for the LFB182G45SG9A272 filter recommended in the Murata LBEH5HMZPC datasheet? Where do we get the latest firmware for the LBEH5HMZPC which is loaded by the Linux driver (fw_bcmdhd.bin, fw_bcmdhd_apsta.bin and fw_bcmdhd_mfgtest.bin). And may I know where I could find the latest versions of CYW4339 firmware? Thanks a lot! Hao |
2个回答
不能使用内部LPO。你是如何得到这个模块的?你使用的主机是什么?
以上来自于百度翻译 以下为原文 You cannot use internal LPO. How did you get the module? What host processor are you using? |
只有小组成员才能发言,加入小组>>
788个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7459 浏览 0 评论
2492 浏览 1 评论
2184 浏览 1 评论
4046 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2095 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7948浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6520浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
760浏览 2评论
736浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
8372浏览 2评论
/9
GMT+8, 2025-12-17 18:45 , Processed in 0.772230 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3633
