电子发烧友论坛|
亲爱的大家,
关闭影响流程后,我收到以下错误消息(ISE 14.7): ... / usage_statistics_webtalk.html WebTalk报告尚未发送至Xilinx。 请检查您的网络和代理设置。 Webtalk已启用,网络连接效果很好,我可以直接连接Xilinx.com网站。 这是我的WebPack许可证的问题吗? webtalk服务仍然有效吗? 它为什么会发生? 谢谢!! 以上来自于谷歌翻译 以下为原文 Dear all, I recieve the following error message (ISE 14.7) upon closing the Impact process: .../usage_statistics_webtalk.html WebTalk report has not been sent to Xilinx. Please check your network and proxy settings. The Webtalk is enabled, the network connection works great and I can connect Xilinx.com website directly. Is it a problem with my WebPack license? Is the webtalk service still active? Why is it happenning? Thanks!! |
4个回答
@ bjorn314,
这可能是Info消息而不是Error消息,可以忽略。 检查以下AR#33315是否有帮助 http://www.xilinx.com/support/answers/33315.html --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @bjorn314, This might be an Info message instead of Error message which can be ignored. Check if the following AR#33315 helps http://www.xilinx.com/support/answers/33315.html --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
嗨@ bjorn314,
请访问以下链接的第26页:http://china.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf 由于忽略了用户首选项,因此无法关闭webpack的webtalk。 谢谢,Arpan ----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi @bjorn314, Please go through page-26 of following link http://china.xilinx.com/support/documentation/sw_manuals/xilinx14_7/irn.pdf You can't turn-off webtalk for webpack as user preference is ignored. Thanks, Arpan ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨@ bjorn314,
这是错误还是仅仅是INFO消息? 谢谢,Nupur ----------------------------------------------- --------------------------------------------- Google在发布之前提问 。 如果某人的帖子回答了您的问题,请将帖子标记为“接受为解决方案”。 如果你看到一个特别好的和信息丰富的帖子,考虑给它Kudos(点击星标)。 以上来自于谷歌翻译 以下为原文 Hi @bjorn314, Is it an error or just an INFO message? Thanks, Nupur -------------------------------------------------------------------------------------------- Google your question before posting. If someone's post answers your question, mark the post as answer with "Accept as solution". If you see a particularly good and informative post, consider giving it Kudos (click on the star mark). |
嘿伙计们,谢谢你的快速回复
消息似乎是信息,而不是错误,一切似乎都没问题。 我知道我可以禁用它。 但是,我很好奇是否仍然支持ISE webtalk并为Xilinx工作。 我不知道我的部门是否确实存在网络问题。 谢谢 以上来自于谷歌翻译 以下为原文 Hey guys, thanks for the quick replies The message seems to be info, not error, and everything seems OK. I know I can disable it. However, I'm curious whether the ISE webtalk is still supported and working for Xilinx. I'm troubled whether is it indeed a network problem in my department. Thanks |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 07:24 , Processed in 0.820034 second(s), Total 78, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2629
