电子发烧友论坛|
在win7机器上我已经使用Vee 9.2几年了,没问题。
2个星期前有一个强制更新(安捷伦IT,没有选择),当我收到附加的错误消息后我尝试了VEE。 我当时正在旅行,所以想“当我回来时修好它”。 我不知道这是Windows更新(包括.net 3.5.1和.net 4),但它似乎是可疑的。 我们的IT中没有人(当然是外包)可以修复它。 我试过:卸载9.2,安装9.3,安装.net 3.5(它似乎没有安装或它没有显示在控制面板中的程序和功能)。 尝试使用EVAL副本(如果许可证不好)。 尝试从内部和外部网站安装。 尝试重启很多。 然后我“回到8.22.13更新之前”,但恢复点不存在(可能是由于尝试了所有的9.3安装)。 所有人都有相同的sympton,vee启动启动画面几分钟,然后弹出崩溃错误。 我真的,真的不想重新映像这台电脑,还有其他建议吗? 以上来自于谷歌翻译 以下为原文 I've been on Vee 9.2 for a couple of years on win7 machine, no problem. 2 weeks ago there was a forced update (Agilent IT, no choice) and when I tried VEE after I get the attached error message. I was travelling at the time so thought "fix it when I get back". I don't know that it was the windows update (included .net 3.5.1 and .net 4) but it seems suspicious. No one in our IT (outsourced of course) can fix it. I have tried: uninstallng 9.2, installing 9.3, installing .net 3.5 (it doesn't seem install or it doesn't show up in programs and features in control panel). Tried using EVAL copy (in case of a bad license). Tried installing from internal and external sites. Tried rebooting lots. then I thught "go back before the 8.22.13 update" but the restore point wasn't there (probably due to trying all the 9.3 installs). All have the same sympton, vee startup splash shows for a few minutes, then the crash error pops up. I really, really don't want to re-image this computer, any other suggestions? 附件
1个回答
看起来这是一个问题,因为死于SSD驱动器(****!)。
几个文件坏了,丢失了磁盘错误; 试图将SSD克隆到另一个驱动器,没有好处(工业驱动器克隆器无法成功读取SSD)。 因此,当新的SDD出现时,可能不得不重新计算机...至少它们更大! 以上来自于谷歌翻译 以下为原文 Looks like this is a problem due to a dieing SSD drive (****!). Several files have gone bad, lost of disk errors; Tried to Clone the SSD to another drive, no good (Industrial drive cloner couldn't successfully read the SSD). So, probably have to repave the computer when the new SDD's show up... at least their bigger! |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 15:26 , Processed in 0.669027 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1686
