电子发烧友论坛|
你好!
我刚开始使用Agilent VEE 9.2,需要一些我需要帮助的程序。 我不知道在哪里放这个帖子所以我猜到了VEE软件论坛。 在这个程序中,我需要将几个乐器的所有命令存储到一个特定的“命令”或“框”中。 然后我必须在这个框中提出我自己的命令,这样就可以只用我的命令就可以将命令写入每个操作。 例如:如果一个仪器需要“FREQ:CENT”,100,“MHZ”作为命令而另一个需要“FREQ:C”,100,“MHZ”,我必须将这些命令存储到一个盒子里 可以使用我自己的命令“FREQ:CEN”,100,“MHZ”与每个乐器说话。 我不是在寻找整个解决方案! 只有一些解释我怎么能使这成为可能。 例如,我应该使用哪些项目或者应该如何构建程序! 我是VEE的新手,所以我现在很难用安捷伦语言。 如果您需要更多解释此任务,我将非常乐意尝试解释更多! 一定要尽可能清楚地解释! 我想学习,而不是作弊。 谢谢 :) 以上来自于谷歌翻译 以下为原文 Hello! I just started using Agilent VEE 9.2 and need some help with a program I need to make. I was not sure where to put this thread so I guessed my way to VEE Software Forums. In this program I need to store all commands for several instruments into one specific "command" or "box". Then I have to come up with my own commands to this box which should make it possible to write commands to every insturments with only my command. For example: If one instrument requires "FREQ:CENT ", 100, "MHZ" as a command and the other one "FREQ:C ", 100, "MHZ", I have to store these commands into one box which will make it possible with my own command "FREQ:CEN ", 100, "MHZ" to speak to every instrument. I am not looking for the entire solution! Only some explanations for how I could make this possible. For example what items I should use or how the program should be built up! I am very new to VEE so I am having a hard time with Agilent language at the moment. If you need more explanasion for this task I will be very glad to try to explain some more! Be sure to try to explain as clear as possible! I want to learn, not cheat. Thanks :) |
1个回答
你好。
你能解释一下吗? 我相信你已经知道如何使用Direct IO对象了? 很快就会听到你的消息:) -mk编辑:changmeikuan于2012年9月18日下午5:17 以上来自于谷歌翻译 以下为原文 Hello. Can you explain further? I believe you already know how to use Direct IO object? Hear from you soon :) -mk Edited by: changmeikuan on Sep 18, 2012 5:17 PM |
只有小组成员才能发言,加入小组>>
1845 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2450 浏览 5 评论
3460 浏览 3 评论
1845浏览 0评论
417浏览 0评论
/9
GMT+8, 2025-12-2 18:42 , Processed in 0.764524 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1587
