电子发烧友论坛扫一扫,分享给好友
我有一个ISE浮动服务器许可证,适用于Windows Server 2008,64位。
我现在也想让它为Vivado工作。 我已按照说明执行此操作,但许可证可执行文件似乎不起作用。 当我运行'installanchorservice.exe'时,我得不到任何输出。 我期待它告诉我它已经成功了。 如果我输入installanchorsevice.exe,我什么都没得到,甚至没有错误。 这是正常的吗? 以上来自于谷歌翻译 以下为原文 I have an ISE floating server license working on Windows Server 2008, 64-bit. I want it to work for Vivado now too. I have followed the instructions to do this but the license executables don't seem to work. When I run 'installanchorservice.exe' I get no output whatsoever. I'm expecting it to tell me it has been successful. If I type just installanchorsevice.exe in, I get nothing too, not even an error. Is this normal? |
2个回答
你好@ paulw7,
您正在尝试使用哪个版本的Vivado? 基于激活的许可方案从Vivado 2014.1开始,如果您查看发行说明,Vivado 2014.1和后续版本将停止支持64位的Windows Server 2008。 您需要根据建议迁移到支持的操作系统,您将在此处找到列表 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf(page#14) 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @paulw7, Which version of Vivado are you trying to use? The activation based licensing scheme started from Vivado 2014.1 and if you check the release notes, Vivado 2014.1 and subsequent version stopped supporting Windows Server 2008, 64-bit. You need to migrate to supported OS as per recommendation and you will find the list at http://www.xilinx.com/support/documentation/sw_manuals/xilinx2014_1/ug973-vivado-release-notes-install-license.pdf (page #14) Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
我使用的是最新版本,我刚购买了$ 4k许可证。
所以他们出售浮动许可证,它只适用于Windows 7和8版本? 以上来自于谷歌翻译 以下为原文 I'm using the latest version, I just purchased the $4k license. So they sell a floating license and it only works on Windows versions 7 and 8???? |
只有小组成员才能发言,加入小组>>
3141 浏览 7 评论
3436 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2897 浏览 9 评论
4097 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3082 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1196浏览 1评论
/9
GMT+8, 2025-12-12 08:16 , Processed in 0.653444 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3162
