电子发烧友论坛|
我的许可证服务器硬盘驱动器失败。
我希望从数据库中释放我的两个浮动许可证服务器,以便我可以将它们安装在新服务器中。 埃里克 以上来自于谷歌翻译 以下为原文 My license server hard drive has failed. I would like my two floating license servers released from the database so I can install them in a new server. Eric |
14个回答
你好@ eyc5,
请检查以下主题 http://forums.xilinx.com/t5/Installation-and-Licensing/Activation-based-license-not-recognized-by-Virtual-Machine/td-p/639494 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @eyc5, Please check below thread http://forums.xilinx.com/t5/Installation-and-Licensing/Activation-based-license-not-recognized-by-Virtual-Machine/td-p/639494 Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
嗨埃里克,
您使用的是基于激活的许可还是基于证书的许可? 此信息有助于为您提供重新托管许可证文件的步骤。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Eric, Are you using activation based licensing or certificate based licensing? This information is helpful to provide you with the steps for rehosting the license file. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨,对于基于证书的许可证http://www.xilinx.com/support/answers/36136.html对于基于激活的许可证http://www.xilinx.com/support/answers/61960.html
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi, For certificate based license http://www.xilinx.com/support/answers/36136.html For activation based license http://www.xilinx.com/support/answers/61960.htmlThanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我有一个基于激活的许可证,我无法返回许可证。
请告诉我你需要知道的两个基于激活的licesnses,以便它们可以从我的帐户中删除,以便我可以重新安装它们。 谢谢。 埃里克 以上来自于谷歌翻译 以下为原文 I have an activation based license, and it is not possible for me to return the license. please tell me what you need to know about the two activation based licesnses so they can be removed from my account so I can reinstall them. Thank you. Eric |
嗨埃里克,
您是否已将生成的激活许可证安装到计算机上? 如果没有,为什么? 在此处共享许可证文件。 还共享以下命令的输出:xlicsrvrmgr -l“format = xml” 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi Eric, Did you install the generated activation licenses on to the machine? If not, why? Share the license files here. Also share the output of the following command: xlicsrvrmgr -l "format=xml" Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
嗨Eric,在这种情况下,您可以提交SR @ http://www.xilinx.com/support/service-portal.html(根据许可部分)
谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi Eric, In that case, you can file a SR @ http://www.xilinx.com/support/service-portal.html (under license section)Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
我似乎无法登录以获得服务请求。我不断让这个蓝色轮子在放大玻璃上旋转。
我无法访问旧硬盘或数据。 它已经崩溃,不再可访问。 埃里克 以上来自于谷歌翻译 以下为原文 I cant seem to get logged in to get a service request in. I keep getting this blue wheel spinning around a magnify glass. I dont have access to the old hard drive or data. it has crash and is not accessible anymore. Eric |
你好@ eyc5,
你使用的是哪种浏览器? 您应该使用最新版本的Google Chrome或Mozilla Firefox或使用Internet Explorer 11或更高版本来访问SR门户。 还尝试清除浏览器缓存。 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hello @eyc5, Which browser are you using? You should use latest version of Google Chrome or Mozilla Firefox or Use Internet Explorer 11 or higher to access SR portal. Also try clearing browser cache. Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
好的我尝试了多个浏览器,但我会尝试清除缓存。
以上来自于谷歌翻译 以下为原文 Ok I tried multiple browers, but I will try clearing the cache. |
好的我先得到这个错误:
遇到错误。 指定的用户名/密码无效。(SBL-UIF-00271) 然后当我重装时,它给了我纺车。 并没有前进。 以上来自于谷歌翻译 以下为原文 ok I get this error first: Encountered an error. Invalid username/password specified.(SBL-UIF-00271) then when I hit reload it gives me the spinning wheel. and doesnt advance. |
也许我的工作是阻止它。
我也会在家里试试。 以上来自于谷歌翻译 以下为原文 maybe my work is blocking it. I will try from home as well. |
遇到错误。
指定的用户名/密码无效。(SBL-UIF-00271) 这是我第一次遇到的错误,我无法进入服务请求页面。 我尝试过多台机器和设备。 埃里克 以上来自于谷歌翻译 以下为原文 Encountered an error. Invalid username/password specified.(SBL-UIF-00271) this is the error I first encounter, I am not able to get to the service request page. I have tried from multiple machines and devices. Eric |
请帮助我无法打开服务请求,我真的需要将这两个基于浮动激活的许可证移到新计算机上。
我的旧硬盘死了,我无法退还这些许可证。 请帮忙 这是我不断得到的错误。 遇到错误。 指定的用户名/密码无效。(SBL-UIF-00271) 以上来自于谷歌翻译 以下为原文 Please help I can't open a service request, and I reallly need these two floating activation based licenses moved to a new computer. My old harddrive died and I can not return those licenses. Please help this is error I keep getting. Encountered an error. Invalid username/password specified.(SBL-UIF-00271) |
Xilinx员工无法访问面向Xilinx服务门户的客户。相反,您可以访问内部服务请求管理(SRM)工具.http://compass.xilinx.com/htim_prod/start.swe(支持的浏览器是Chrome,
Firefox,IE 11)。 谢谢和RegardsBalkrishan ----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Xilinx Employees do not have access to the customer facing Xilinx Service Portal. Instead, you can access the internal Service Request Management (SRM) tool. http://compass.xilinx.com/htim_prod/start.swe (Supported browsers are Chrome, Firefox, IE 11).Thanks and Regards Balkrishan -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
只有小组成员才能发言,加入小组>>
3148 浏览 7 评论
3437 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2899 浏览 9 评论
4100 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3083 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1198浏览 1评论
/9
GMT+8, 2025-12-14 08:17 , Processed in 1.187385 second(s), Total 100, Slave 83 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2331
