你好,
我目前正致力于: - ISE13.4 - 浮动许可证,连接到服务器 - ML605 所以我使用ISE / XPS / SDK三重奏...当我在SDK中,并在ML605中为Microblaze编写代码,并连接ML605时,它工作正常......直到ML605循环上电 。 然后....当试图将位文件下载到ML605时挂起SDK ....然后在我必须使用任务管理器关闭SDK并重新打开后许可证被锁定...所以我什么都做不了 ......直到我让IT人员来清除许可证 为什么会发生以下情况: - 为什么SDK处理目标板的电源周期很差? 似乎USB-JTAG之后都搞砸了......难道不应该只是承认另一次重新连接吗? 荒谬的...... - 我如何自己清理许可证? 所有这一切的解决方法是什么? 如果可以,请帮助......我的IT支持很糟糕。 谢谢, -Peter 以上来自于谷歌翻译 以下为原文 Hello, I am currently working on/with: - ISE13.4 - FLOAtiNG LICENSE, connected to server - ML605 So I use the ISE/XPS/SDK trio...when I am in the SDK, and writing code for a Microblaze in the ML605, and connect up the ML605, it works fine...UNTIL I CYCLE THE POWER ON THE ML605. THEN....it hang up SDK when trying to download the bit file to the ML605....then the license is LOCKED after I have to use task manager to close SDK and reopen...so I can't do anything...until I get IT here to clear the license.. WHY does the following happen: - Why does SDK handle the power cycle so poorly of the target boards? seems like the USB-JTAG is all messed up after...shouldn't it just acknowledge another reconnection? rediculous... - How can I cleanr the license myself? What is the fix around all of this? Please help if you can...my IT support is horrible. Thanks, -Peter |
2个回答
SDK使用XMD将比特文件下载到您的主板上,这就是导致挂起的原因。
最好的办法是在重启电源之前断开XMD连接。 以上来自于谷歌翻译 以下为原文 SDK uses XMD to download the bitfiles to your board, and that's what's causing the hang. Best thing would be to disconnect the XMD connection before power cycling. |
嘿阿曼达,
我在工具结构中很天真......我该怎么做? 感谢您的支持, -Peter PS:这是一个常见的问题吗? 这崩溃了吗? 在HP Intel CPU机器上运行Win7 .. 以上来自于谷歌翻译 以下为原文 Hey Amandaw, I am little naive i nthe tool structure...how would I do this? Thanks for the support, -Peter PS: Is this a common problem? This crashing? running Win7 on an HP Intel CPU machine.. |
只有小组成员才能发言,加入小组>>
2414 浏览 7 评论
2821 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2292 浏览 9 评论
3371 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2456 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1049浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
577浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
436浏览 1评论
1998浏览 0评论
721浏览 0评论
GMT+8, 2024-12-19 02:31 , Processed in 1.299092 second(s), Total 79, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
