电子发烧友论坛|
嗨,大家好。
我在安装ISE13.1并运行完全在ISE12.1中的项目后遇到如下问题,我在ISE13.1中检查了.cdc文件是否正确。 那么有人可以给我一些建议吗? 加载CDC项目F: design_projects TO_BE startup startup_test test.cdc成功读取项目F: design_projects TO_BE startup startup_test test.cdccopy F: design_projects TO_BE startup startup_test startup_test_cs.ngc => F : design_projects TO_BE startup startup_test _ngo startup_test_cs_signalbrowser.ngo使用CORE Generator生成核心。 请耐心等待,因为这可能需要几分钟...生成核心1 of 2 icon_pro.ngc ...>收集HDL文件....>创建XST项目...>创建XST脚本文件...>创建XST即时 文件.....失败。 :警告:coreutil - icon_pro的XST失败。 错误:Xst:439 - 无写访问:错误:sim - 在生成期间发现错误。:ERROR:sim - 无法生成'icon_pro'。 生成期间发现错误。:ERROR:sim:877 - 执行IP'ICON时发现错误(ChipScope Pro -See CoreGen Log F: design_projects TO_BE startup startup_test _ngo cs_icon_pro coregen.logERROR:ChipScope:无法 生成icon_pro.ngcERROR:ChipScope:双击源窗口中的test.cdc图标,编辑并修复CDC项目。 以上来自于谷歌翻译 以下为原文 Hi,everyone. I have a problem as below after installing ISE13.1 and running my project which is perfectly in ISE12.1, and I have checked the.cdc file is correct in ISE13.1. So could anyone give me some advice ? Loading CDC project F:design_projectsTO_BEstartupstartup_testtest.cdc Successfully read project F:design_projectsTO_BEstartupstartup_testtest.cdc copy F:design_projectsTO_BEstartupstartup_teststartup_test_cs.ngc => F:design_projectsTO_BEstartupstartup_test_ngostartup_test_cs_signalbrowser.ngo Generating cores using CORE Generator. Please be patient as this can take several minutes... Generating core 1 of 2 icon_pro.ngc... >Gathering HDL files.... >Creating XST project... >Creating XST script file... >Creating XST instantation file... .. FAILED. See CoreGen Log F:design_projectsTO_BEstartupstartup_test_ngocs_icon_procoregen.log ERROR:ChipScope: Unable to generate icon_pro.ngc ERROR:ChipScope: Double-click the test.cdc icon in the sources window to edit and fix the CDC project. |
6个回答
我也得到了这个。
原来C: temp文件夹已被删除。 当我在Windows资源管理器中创建一个新的时,它似乎很好。 虽然不是最有用的错误消息。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 I got this too. Turned out the C:temp folder had been deleted. When I created a new one in Windows explorer it seemed to be fine thereafter. Not the most helpful error message though. View solution in original post |
我曾尝试使用其他版本的winxp系统,但chipscope13.1也失败了。
以上来自于谷歌翻译 以下为原文 I have tried to use other version of winxp system,but chipscope13.1 also failed. |
我也得到了这个。
原来C: temp文件夹已被删除。 当我在Windows资源管理器中创建一个新的时,它似乎很好。 虽然不是最有用的错误消息。 以上来自于谷歌翻译 以下为原文 I got this too. Turned out the C:temp folder had been deleted. When I created a new one in Windows explorer it seemed to be fine thereafter. Not the most helpful error message though. |
可以通过创建文件夹“C: temp”来解决。
以上来自于谷歌翻译 以下为原文 It can be resolved by creating folder "C:temp". |
实际上有一个c: temp文件夹。
我删除了这个文件夹下的所有内容。 但它仍然不起作用。仍显示上述错误。 需要你的帮助! 以上来自于谷歌翻译 以下为原文 actually there is a c:temp folder . and i deleted everything under this folder . but it still not work .still showing the error above. need your help! |
即使它已经老了,我还是在反对激战:Xst:439。
检查您的综合选项并删除“工作目录”下的位置,在这种情况下,工作目录将返回到c:/ TEMP 如果将项目移动到另一台计算机时,syntesis选项 - >工作目录下的字段不为空,例如,ISE可能无法找到该选项中设置的驱动器或工作目录 以上来自于谷歌翻译 以下为原文 even if it is old I was fighting against ERROR:Xst:439. check your synthesis options and delete the location under "work directory" in that case the work directory comes back to be c:/TEMP if the field under syntesis options --> working directory is not blank when you move the project to another computer for example it is possible that ISE is not able to find the drive or the working directory set in the option |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-2 01:57 , Processed in 0.633496 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1393
