我在VISTA 64bit安装ISE 13.1。
有时,当我创建一个新项目,并添加文件时,我收到一个错误:“_ pn.exe已停止工作”,并且ISE已关闭 - 我无法解决问题。 问题是什么? 我该如何解决? Canise 13.1版本适用于VISTA? 以上来自于谷歌翻译 以下为原文 I install ISE 13.1 at VISTA 64bit. Sometimes, when I create a new project, and add files I get an error: "_pn.exe has stopped working" , and the the ISE is closed - I can not work with the problem. What is the problem? How can I fix it? Can ISE 13.1 version works on VISTA? |
1个回答
ISE 13.1是一个新版本,有几个崩溃和其他问题的报告。
建议您打开一个Webcase来报告您的问题(并创建一个错误报告提交)。 然后下载并安装ISE 12.4,看看12.4版本是否适合您。 更多建议: 随时关注Windows更新 尝试使用32位GUI shell而不是64位shell 祝你好运! - 鲍勃埃尔金德 签名:新手的自述文件在这里:http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369总结:1。 阅读手册或用户指南。 你读过手册了吗? 你能找到手册吗?2。 搜索论坛(并搜索网页)以寻找类似的主题。 不要在多个论坛上发布相同的问题。 不要在别人的主题上发布新主题或问题,开始新的主题!5。 学生:复制代码与学习设计不同.6“它不起作用”不是一个可以回答的问题。 提供有用的详细信息(请与网页,数据表链接).7。 您的代码中的评论不需要支付额外费用。 我没有支付论坛帖子的费用。 如果我写一篇好文章,那么我一无所获。 以上来自于谷歌翻译 以下为原文 ISE 13.1 is a new release, and there have been several reports of crashes and other problems. Suggest you open a webcase to report your problem (and create a bug report submission). Then download and install ISE 12.4 and see if the 12.4 release works better for you. Some more suggestions:
Good luck! -- Bob Elkind SIGNATURE: README for newbies is here: http://forums.xilinx.com/t5/New-Users-Forum/README-first-Help-for-new-users/td-p/219369 Summary: 1. Read the manual or user guide. Have you read the manual? Can you find the manual? 2. Search the forums (and search the web) for similar topics. 3. Do not post the same question on multiple forums. 4. Do not post a new topic or question on someone else's thread, start a new thread! 5. Students: Copying code is not the same as learning to design. 6 "It does not work" is not a question which can be answered. Provide useful details (with webpage, datasheet links, please). 7. You are not charged extra fees for comments in your code. 8. I am not paid for forum posts. If I write a good post, then I have been good for nothing. |
只有小组成员才能发言,加入小组>>
2379 浏览 7 评论
2794 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2261 浏览 9 评论
3335 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2427 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
754浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
543浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
364浏览 1评论
1960浏览 0评论
681浏览 0评论
GMT+8, 2024-11-21 21:53 , Processed in 1.281943 second(s), Total 77, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
