扫一扫,分享给好友
你好,
我正在处理一个自定义组件(HTTPS://Github. COM/C47 D/NFR24OI组件),并希望添加对PSoC6设备的支持 使用PSOC5LP和PSOC4,有几个定义可以用来识别它们: CysPoSO5和CysPoSO4。 找不到CysPoS6,所以我的问题是:是否有一个定义来标识我在项目中使用PSoC6?还有其他方法吗? 当做, 卡洛斯 以上来自于百度翻译 以下为原文 Hi, I'm working on a custom component (https://github.com/C47D/nRF24_Component) and would like to add support for PSoC6 devices With PSoC5LP and PSoC4 a couple of defines were available to identify them: CY_PSOC5 and CY_PSOC4 respectively. Couldn't find CY_PSOC6, so my question is: is a define available to identify i'm using a PSoC6 on my project? or any other way to do this? Regards, Carlos |
2个回答
你好,卡洛斯,
目前,我们没有任何定义,它标识代码中的PSoC 6。但是,我们已经定义了部件号,可以用来识别PSoC 6。你甚至可以根据你正在使用的部分删除代码。 以下为PSoC 63系列: 如果定义(CY8C6336BZIILBLF03) El ILIF定义(CY8C6316BZIILBLF03) El ILIF定义(CY8C6316BZIILBLF53) El ILIF定义(CY8C6336BZIILBLD13) El ILIF定义(CY8C637BZIYBLD43) El ILIF定义(CY8C637BZIYBLD33) El ILIF定义(CY8C637BZIYBLD53) El ILIF定义(CY8C634 7FMII1.BLD13) El ILIF定义(CY8C634 7FMIILBLD43) El ILIF定义(CY8C634 7FMIILBLD33) El ILIF定义(CY8C634 7FMIILBLD53) 否则 定义CythNo.PoSOC6 第二节 γIFNDEF CYN-NON-PSOC6 定义CyspSOC6 第二节 还可以在为PSoC 6构建时为M0+和M4在编译器设置中定义的附加预处理器定义CysPoS6。 当做, Meenakshi Sundaram R 以上来自于百度翻译 以下为原文 Hello Carlos, Currently we do not have any defines, which identifies PSoC 6 in a code. However, we have defines for part number, which you can use to identify PSoC 6. And you can even remove codes depending on the part# you are using. Something like below for PSoC 63 family: #if defined (CY8C6336BZI_BLF03) #elif defined (CY8C6316BZI_BLF03) #elif defined (CY8C6316BZI_BLF53) #elif defined (CY8C6336BZI_BLD13) #elif defined (CY8C6347BZI_BLD43) #elif defined (CY8C6347BZI_BLD33) #elif defined (CY8C6347BZI_BLD53) #elif defined (CY8C6347FMI_BLD13) #elif defined (CY8C6347FMI_BLD43) #elif defined (CY8C6347FMI_BLD33) #elif defined (CY8C6347FMI_BLD53) #else #define CY_NON_PSOC6 #endif #ifndef CY_NON_PSOC6 #define CY_PSOC6 #endif You can also define CY_PSOC6 in the additional preprocessor defines in the compiler settings for both M0+ and M4 when building for PSoC 6. Regards, Meenakshi Sundaram R |
斯图尔特233 发表于 2018-12-11 14:35 嗨,Meenakshi, 谢谢你的回复,现在我只是在用 若定义(CygGPIOH) 到目前为止,它是工作的,因为PSoC6设备是唯一的设备(我知道),这就定义了,所以我有点容易维护它。 当做 卡洛斯 以上来自于百度翻译 以下为原文 Hi Meenakshi, Thanks for the reply, for now i'm just using #if defined (CY_GPIO_H) so far it works because PSoC6 devices are the only devices (that i know of) that does that define, so it's a little bit easier for me to maintain it. Regards Carlos |
只有小组成员才能发言,加入小组>>
725个成员聚集在这个小组
加入小组1933 浏览 1 评论
1683 浏览 1 评论
3443 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1604 浏览 6 评论
1402 浏览 1 评论
GMT+8, 2024-6-22 18:44 , Processed in 0.711786 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
