电子发烧友论坛|
我参加了一个数字设计课程,要求我下载ISE Webpack。
由于技术困难,我不断收到错误消息。 我已通过邮件中提供的地址向网站管理员发送了电子邮件。 现在真的有技术上的困难吗? 我试着在我的Windows 7 PC和Macbook上下载。 这与验证我的姓名和公司(学校)有关吗? 谢谢您的帮助, 詹姆士 以上来自于谷歌翻译 以下为原文 I'm enrolled in a digital design class which requires me to dowload the ISE Webpack. I keep getting an error message due to technical difficulties. I've emailed the webmaster at the address provided in the message. Are there really technicial difficulties now? I'm tried dowloading on my Windows 7 PC and my Macbook. Does this have something to do with verifying my name and company (the school)? Thanks for the help, James |
6个回答
如果您认为在第一次尝试下载时确实存在技术问题,那么在再次尝试之前清除浏览器缓存可能会有所帮助。
- Gabor 以上来自于谷歌翻译 以下为原文 If you think that there actually were technical difficulties when you first tried the download, then it might help to clear your browser cache before trying again. -- Gabor |
嗨,
尝试从以下答案记录下载最新的ISE:http://www.xilinx.com/support/answers/57840.html 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Try downloading latest ISE from the following answer record: http://www.xilinx.com/support/answers/57840.html Thanks -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
我试图在在线支持上获取案例ID,但是我收到了另一条关于不符合美国出口法律的错误消息。
这与没有下载有关吗? 我输入了学校的地址和电话号码。 以上来自于谷歌翻译 以下为原文 I tried to get a case ID on the online support, but I get another error message about not complying with US export laws. Does this have something to do with not getting the download? I inputted my school's address and phone number. |
也许我会尝试获得早期版本的ISE。
我使用早期版本创建的文件是否可由我的14.7项目合作伙伴读/写? 我必须提交.sch和.v文件进行评分。 谢谢。 以上来自于谷歌翻译 以下为原文 Maybe I'll try getting an earlier version of ISE. Are the files I create with an earlier version read/writeable by my 14.7 project partners? I have to submit .sch and .v files for grading. Thanks. |
我不确定原理图,但Verilog文件只是文本,因此任何版本都可以读取它们。
ISE项目文件(* .xise)只能由相同或更新版本读取。 如果您想共享项目而不是最好使用相同版本的ISE。 如果原型之间的原理图格式发生了变化,那么应该可以从较新版本的ISE中读取较旧的格式。 然而,相反的情况并非如此。 也许您可以从项目合作伙伴或您的老师那里获得一些帮助来下载ISE。 - Gabor 以上来自于谷歌翻译 以下为原文 I'm not sure about schematics, but Verilog files are just text, so any version could read them. The ISE project file (*.xise) is readable only by the same or newer versions. If you want to share a project than it's best to use the same version of ISE. If the schematic format has changed between versions, again it should be possible to read older ones from the newer version of ISE. However the reverse would not be true. Perhaps you could get some help for downloading ISE from your project partners or your teacher. -- Gabor |
sinosmoke写道:
我试图在在线支持上获取案例ID,但是我收到了另一条关于不符合美国出口法律的错误消息。 这与没有下载有关吗? 我输入了学校的地址和电话号码。 学生没有资格获得网络案例支持。 你需要通过你的导师。 - Gabor 以上来自于谷歌翻译 以下为原文 sinosmoke wrote:Students are not eligible for web case support. You'd need to get it through your instructor. -- Gabor |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2873 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1325浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1167浏览 1评论
/9
GMT+8, 2025-12-1 18:50 , Processed in 0.620160 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1393
