扫一扫,分享给好友
大家好,
我正在尝试在Ubuntu 13.10上安装Vivado 2013.2我按照描述的步骤进行操作(sudo apt-get install openjdk-7-jre,sudo mv /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/ libjvm.so /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/libjvm.so.old sudo ln -s / usr / lib / jvm / java-7-openjdk-amd64 / jre / lib / amd64 / server / libjvm.so /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/ 但是当我尝试“添加Ip”并且我选择了一个块我有这个错误: 错误:[Vivado 12-106] ***异常:java.lang.NumberFormatException:对于输入字符串:“1,08846”(请参阅/home/sabeur/vivado_pid3993.debug) 有人可以帮助我吗? 非常感谢 最好的祝福 以上来自于谷歌翻译 以下为原文 Hello every body, I am trying to install Vivado 2013.2 on Ubuntu 13.10 I hace followed steps described ( sudo apt-get install openjdk-7-jre, sudo mv /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/libjvm.so /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/libjvm.so.old sudo ln -s /usr/lib/jvm/java-7-openjdk-amd64/jre/lib/amd64/server/libjvm.so /opt/Xilinx/Vivado/2013.2/tps/lnx64/jre/lib/amd64/server/ but when i try to "add Ip" and i choose a block i have this ERROR : ERROR: [Vivado 12-106] *** Exception: java.lang.NumberFormatException: For input string: "1,08846" (See /home/sabeur/vivado_pid3993.debug) Some one can help me ? Thanks a lot Best regards |
4个回答
嗨,
Vivado不支持操作系统Ubuntu。 请检查以下链接。 http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_2/ug973-vivado-release-notes-install-license.pdf(Page#12) 谢谢, 阿希什 问候,阿希什----------------------------------------------- - - - - - - - - - - - - - - - - - - - - - - - -请注意- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。感谢Kudos .-------------------- -------------------------------------------------- ------------------------ 以上来自于谷歌翻译 以下为原文 Hi, The operating system Ubuntu is not supported by Vivado. Please check below link. http://www.xilinx.com/support/documentation/sw_manuals/xilinx2013_2/ug973-vivado-release-notes-install-license.pdf (Page # 12) Thanks, Ashish Regards, Ashish ---------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. ---------------------------------------------------------------------------------------------- |
看起来环境变量LANG =和/或LC_ALL =在Vivado和Java之间的设置存在差异。
我将手动设置为您的语言环境,并确保代表您启动的进程(如Java)使用相同的进程。 以上来自于谷歌翻译 以下为原文 Looks like there is a difference in the setting of the environment variables LANG= and/or LC_ALL= between Vivado and Java. I would set both manually to your locale and make sure that processes that start on your behalf--such as Java--are using the same. |
怎么做?
对不起,我不是很喜欢Ubuntu谢谢 以上来自于谷歌翻译 以下为原文 And how to do that ? sorry i am not very fan of Ubuntu thanks |
嗨,
检查此主题:http://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-crashes-with-Norwegian-locale/td-p/439900 谢谢 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Check this thread: http://forums.xilinx.com/t5/Installation-and-Licensing/Vivado-crashes-with-Norwegian-locale/td-p/439900 Thanks -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
只有小组成员才能发言,加入小组>>
2429 浏览 7 评论
2830 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2298 浏览 9 评论
3378 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2468 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1286浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
592浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
455浏览 1评论
2010浏览 0评论
736浏览 0评论
GMT+8, 2024-12-26 21:58 , Processed in 1.378125 second(s), Total 83, Slave 67 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
