尝试在虚拟机上安装许可证服务器时,我们的IT部门收到以下错误:
8:38:34(lmgrd)pid 106208:38:34(lmgrd)完成重读8:38:34(lmgrd)FlexNet许可(v11.11.0.0 build 106800 x64_n6)在###。###开始。###。## #。###(IBM PC)(2014/5/23)8:38:34(lmgrd)版权所有(c)1988-2012 Flexera Software LLC。 保留所有权利.8:38:34(lmgrd)万维网:http://www.flexerasoftware.com8:38:34(lmgrd)许可文件:C: Licenses Xilinx Xilinx.lic8:38 :34(lmgrd)lmgrd tcp-port 21008:38:34(lmgrd)启动供应商守护程序... 8:38:34(lmgrd)启动xilinxd(pid 13756)8:38:39(lmgrd)xilinxd退出状态53 (环境变量LM_BINDING_AGENT的值不正确)8:38:39(lmgrd)不会提供任何功能。 虽然这个错误似乎是“常见的”,但找到关于如何纠正它的说明却很困难。 有什么建议么? 解决方案的链接也会起作用。 据我所知,FlexNET正在检测虚拟机并退出。 我找不到涵盖此主题的Xilinx常见问题解答。 在xilinx.com上搜索LM_BINDING_AGENT不会返回任何匹配。 也许Xilinx可以在该关键字上添加常见问题解答。 谢谢 以上来自于谷歌翻译 以下为原文 When trying to install the license server on a Virtual Machine, our IT department is getting the following error: 8:38:34 (lmgrd) pid 10620 8:38:34 (lmgrd) Done rereading 8:38:34 (lmgrd) FlexNet Licensing (v11.11.0.0 build 106800 x64_n6) started on ###.###.###.### (IBM PC) (5/23/2014) 8:38:34 (lmgrd) Copyright (c) 1988-2012 Flexera Software LLC. All Rights Reserved. 8:38:34 (lmgrd) World Wide Web: http://www.flexerasoftware.com 8:38:34 (lmgrd) License file(s): C:LicensesXilinxXilinx.lic 8:38:34 (lmgrd) lmgrd tcp-port 2100 8:38:34 (lmgrd) Starting vendor daemons ... 8:38:34 (lmgrd) Started xilinxd (pid 13756) 8:38:39 (lmgrd) xilinxd exited with status 53 (Incorrect value for the environment variable LM_BINDING_AGENT) 8:38:39 (lmgrd) No feature will be served. Although this error appears to be "common", finding instructions on how to correct it is proving difficult. Any suggestions? A link to a solution would work too. As far as I can tell, FlexNET is detecting the Virtual Machine and exiting. I could not find a Xilinx FAQ that covers this topic. Searching xilinx.com for LM_BINDING_AGENT returns no hits. Perhaps Xilinx could attach a FAQ to that keyword. Thanks |
3个回答
嗨,你在VM上使用哪个操作系统?还粘贴用于启动服务器的命令?确保lmgrd.exe,lmutil.exe,xilinxd.exe在同一目录或位置。谢谢,Vinay
-------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi, Which OS are you using on VM? Also paste the command that you are using for starting the server? Make sure lmgrd.exe, lmutil.exe, xilinxd.exe are in same directory or location. Thanks, Vinay-------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
None
以上来自于谷歌翻译 以下为原文 The person in our IT department who is setting up the Xilnx virtual machine is out until next week. I can give you what I know. OS : Windows 2012 server VM : not sure, but I have heard VMware mentioned Command line: I will have to ask when the IT person returns File locations: I will have to ask when the IT person returns Note: It seems we have multiple FlexNet servers running for several programs. The Xilnx license server is the only one with this problem. Yes, I have tried www.google.com. You might want to change your signature; it does not "read nicely". As far as I can tell, with the help of www.google.com, from Chapter 15 of Flexera Software's installation manual, which Xilinx does not provide, more recent versions of FlexNet now detect certain Virtual Machines and refuse to load when FlexNet detects the virtual machine. One must use a FlexNet program called "lmbind" to provide more information to FlexNet. Xilnx does not provide lmbind as part of its licensing tools. The above is all I have for now. I tried opening a Webcase ticket, but it seems that, although we are using purchased licenses, I can not open a Webcase ticket since my email address is from an university. I currently am attempting to remedy the situation. This process of setting up a Xilinx license server is turning out to be far more involved than it should be. Xilnx needs to create a installation guide related to setting up its FlexNet license servers. Thanks -bkozykowskipsu |
我有更多的信息给你:
操作系统:Windows Server 2012 R2 Standard 要启动的命令:不使用命令,使用FlexLM启动服务器。 已验证所有文件都在同一目录中,但另一个目录中的许可证文件除外。 谢谢 -bkozykowskipsu 以上来自于谷歌翻译 以下为原文 I have some more information for you: OS : Windows Server 2012 R2 Standard Command to start: Not using a command, using FlexLM to start the server. It was verified that all files are in the same directory, except for the license file which is in another directory. Thanks -bkozykowskipsu |
只有小组成员才能发言,加入小组>>
2294 浏览 7 评论
2703 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2188 浏览 9 评论
3263 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2333 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
601浏览 1评论
1663浏览 1评论
162浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2316浏览 0评论
632浏览 0评论
GMT+8, 2024-9-3 10:19 , Processed in 1.100835 second(s), Total 51, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
