扫一扫,分享给好友
我是购买Vivado许可证的公司的分包商。
出于某种原因,我无法使用我的帐户信息激活许可证凭证。 有关我的帐户的哪些信息需要与我工作的公司匹配才能获得许可证凭证? -Jason 以上来自于谷歌翻译 以下为原文 I'm a sub-contractor to a company that purchased a Vivado license. For some reason I cannot activate the license voucher with my account information. What information about my account is required to match the company I work for in order to get the license voucher activated? -Jason |
3个回答
嗨@jmaranhao
您能否共享尝试激活许可证时遇到的确切错误消息? purchaselicense将添加到采购订单中提供的帐户中。 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @jmaranhao Can you share the exact error message that you encounter when trying to activate the license? The purchased license will be added to the account that is provided in the purchase order. Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
错误消息是“无效的优惠券代码。请重试。”
以上来自于谷歌翻译 以下为原文 The error message is "Invalid voucher code. Please try again." |
你好@ jmaranhao
查看此答复记录:http://www.xilinx.com/support/answers/45537.html 谢谢, 维奈 -------------------------------------------------- ------------------------------------------您是否尝试在Google中输入问题? ? 如果没有,你应该在发布之前。 此外,MARK这是一个答案,以防它有助于解决您的查询/问题。给予帮助您找到解决方案的帖子。 以上来自于谷歌翻译 以下为原文 Hi @jmaranhao Check this answer record: http://www.xilinx.com/support/answers/45537.html Thanks, Vinay -------------------------------------------------------------------------------------------- Have you tried typing your question in Google? If not you should before posting. Also, MARK this is as an answer in case it helped resolve your query/issue.Give kudos to the post that helped you to find the solution. |
只有小组成员才能发言,加入小组>>
2267 浏览 7 评论
2671 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2159 浏览 9 评论
3233 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2303 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
553浏览 1评论
1620浏览 1评论
121浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2276浏览 0评论
589浏览 0评论
GMT+8, 2024-8-11 08:58 , Processed in 1.017759 second(s), Total 51, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
