你好
我尝试使用轮毂电机。带霍尔传感器的300W。 我使用了workbench,最终成功运行了Motor Profiler。 并获得电机参数,PID增益。 在此之后,应用这些参数并尝试运行电机。 但由于此错误,它不会运行。 ''启动失败''。 我引用了一些故障排除。并尝试了几件事。 就像减少观察者的G2增益一样。并且在Observer + PLL中增加方差阈值。但仍然没有奏效。 我在启动时期望更高的电流,如1A。但我目前的米 仅显示0.2A。电流表只显示整体电流,而不仅仅是相电流。 现在我该怎么办? (感谢Gigi的大力帮助) 以上来自于谷歌翻译 以下为原文 Hello I try to use In-Wheel motor. 300W with Hall sensor. I used workbench and finally succeeded to run Motor Profiler . And got motor parameters, PID gains. After this, applied these parameters and tried to run the motor. But because of this error, it doesn't run. ''Start-up Failure''. I referenced some troubleshoot. and tried several things. Like decreasing G2 gain in observer. and increasing variance threshold in Observer+PLL. But still didn't work. I expected higher current like 1A when starting up. But my current meter shows just 0.2A. Current meter just show overall current not just phase current though. Now what can I try? (Thanks Gigi for your big help) |
1个回答
Ciao Lino
这似乎是另一篇文章的重复 /public/STe2ecommunities/motordriver_ics/Lists/Motor%20Control%20Firmware%20and%20Software/Flat.aspx?RootFolder=https://my.st.com/public/STe2ecommunities/motordriver_ics/Lists/Motor%20Control%20Firmware%20and %20Software /不%20enough%20torque%20when%20using%20MC%20PMSM%20FOC%20Lib%204.2&安培; FolderCTID = 0x01200200770978C69A1141439FE559EB459D758000CE106710FFA6574FB92BFFEFCE2DD930&安培; currentviews = 27 再见 梁咏琪 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Ciao Lino this seems a duplicate of the other post /public/STe2ecommunities/motordriver_ics/Lists/Motor%20Control%20Firmware%20and%20Software/Flat.aspx?RootFolder=https://my.st.com/public/STe2ecommunities/motordriver_ics/Lists/Motor%20Control%20Firmware%20and%20Software/Not%20enough%20torque%20when%20using%20MC%20PMSM%20FOC%20Lib%204.2&FolderCTID=0x01200200770978C69A1141439FE559EB459D758000CE106710FFA6574FB92BFFEFCE2DD930¤tviews=27 Ciao Gigi Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
2741 浏览 1 评论
3244 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1813 浏览 1 评论
3653 浏览 6 评论
6043 浏览 21 评论
1342浏览 4评论
203浏览 3评论
对H747I-DISCO写程序时将CN2的st-link复用为usart1,再次烧录时无法检测到stlink怎么解决?
356浏览 2评论
STM32G474RE芯片只是串口发个数据就发烫严重是怎么回事?
445浏览 2评论
STM32处理增量式编码器Z信号如何判断中断是正转的还是反向转的?
275浏览 2评论
GMT+8, 2024-12-26 02:37 , Processed in 1.292064 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
