电子发烧友论坛|
*快速提问。* 85053B验证套件上的衰减器是否精确无槽?
*想要了解的背景。*我想在eBay上购买85053B 3.5毫米验证套件,但它们非常昂贵。 我发现了一个85053B套件,其衰减器丢失了180美元,还购买了85053A,它具有相同的衰减器部件号。 所以我的计划是*使用85053B的盒子和航空公司*从85053A中取出衰减器*发送部件组合,这将给我一个完整的85053B到安捷伦进行校准。 根据HP / Agilent手册,85053A和B中的衰减器具有相同的部件号:* 85053-60001(20 dB)* 85053-60002(40 dB)我有点惊讶85053A套件中的衰减器不是 精密无插槽设备,但有4个插槽。 这是正常的吗? 我认为鉴于验证套件的目的,它将尽可能准确,因此使用无槽设备。 戴夫 以上来自于谷歌翻译 以下为原文 *Quick question.* Are the attenuators on the 85053B verification kit precision slotless? *Background for wanting to know.* I was looking to buy an 85053B 3.5 mm verification kit on eBay, but they are pretty damm expensive. I found an 85053B kit with the attenuators missing for $180, and also purchased an 85053A which has the same part numbers for the attenuators. So my plan was to * Use the box and airlines from the 85053B * Remove the attenuators from the 85053A * Send the combination of parts, which will give me a complete 85053B to Agilent for calibration. According to the HP/Agilent manuals, the attenuators in the 85053A and B are the same part numbers: * 85053-60001 (20 dB) * 85053-60002 (40 dB) I was a bit surprised the attenuators in the 85053A kit are not precision slot-less devices, but have 4 slots. Is that normal? I would have thought given the purpose of a verification kit it would have been made as accurate as possible, and so use slotless devices. Dave |
2个回答
我不确定更新的套件,但我的85053B在衰减器上有插槽连接器...它的日期代码为2815,所以它将它放在1988年左右....它甚至还包括一个盒式磁带。
我会看看我是否可以在某处找到更新的套件 以上来自于谷歌翻译 以下为原文 I am not sure about newer kits, but my 85053B has slotted connectors on the attenuators...it has a date code of 2815 so that puts it around 1988....it even has a tape cartridge included. I will see if I can find a newer kit somewhere |
胡bbs2 发表于 2018-11-30 19:21 > {quote:title = jvall写道:} {quote}>我不确定更新的套件,但我的85053B在衰减器上有插槽连接器......它的日期代码为2815,所以它将它放在1988年左右...... 。甚至包括一个磁带盒。 >>我会看看我是否可以在某处找到更新的套件谢谢。 我的85053A显然比较老,但至少你的衰减器是开槽的,这表明安捷伦会使用开槽连接器校准我的85053B。 由于85053B支持PNA,如果新型号的泡沫是USB棒或类似物的切口,我会感兴趣。 我很想从安捷伦那里购买泡沫,并且我也会用USB棒上的数据进行校准,以防我购买PNA。 它花了我569美元购买*两个*不完整的85053B 180美元和85053A缺少磁盘389美元。 这比eBay上的唯一85053B便宜了4222美元! 当然,在大量使用之前,我仍然需要向安捷伦支付校准费用。 DaveEdited:drkirkby于2013年11月27日下午6:41 以上来自于谷歌翻译 以下为原文 > {quote:title=jvall wrote:}{quote} > I am not sure about newer kits, but my 85053B has slotted connectors on the attenuators...it has a date code of 2815 so that puts it around 1988....it even has a tape cartridge included. > > I will see if I can find a newer kit somewhere Thank you. My 85053A is obviously older, but at least the fact your attenuators are slotted, it would indicate that Agilent would calibrate my 85053B with slotted connectors. Since the 85053B supports the PNA, I'd be interested if the foam on a newer model a cutout for a USB stick or similar. I'd be tempted to buy the foam from Agilent and it calibrated with data on USB stick too, in case I buy a PNA. It cost me $569 buying *both* the incomplete 85053B at $180 and the 85053A which is missing the disks at $389. That's quite a bit cheaper than the only 85053B on eBay now at $4222! Of course I still have to pay Agilent to calibrate it before it is much use. Dave Edited by: drkirkby on Nov 27, 2013 6:41 PM |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1843浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 17:26 , Processed in 0.574132 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1471
