电子发烧友论坛|
我最近将我的8720D送到英国的安捷伦进行校准。
我大概一周前回来了。 在安捷伦发布的校准证书上:http://sage.math.washington.edu/home/kirkby/Agilent-standard-calibration-with-uncertainties-for-8720D-vector-network-analyzer.pdf我发现3.5毫米 使用的验证套件是过时的85053A,而不是目前的85053B。 使用该套件优于目前的85053B有什么优势吗? 我想买一个验证套件,所以想知道什么是最好买的型号。 我猜测8720D的校准程序是在85053B可用之前开发的,当过时的85053A完成工作时,安捷伦认为没有理由更新使用当前套件的程序。 但如果使用过时的套件有优势,我会在寻找套件时牢记这一点。 根据我在目前的85053B上可以找到的信息,它确实支持8720系列,所以从表面上看,购买85053B将是更好的选择。 戴夫 以上来自于谷歌翻译 以下为原文 I recently sent my 8720D to Agilent in the UK for calibration. I got it back a week or so ago. On the calibration certificate issued by Agilent: http://sage.math.washington.edu/home/kirkby/Agilent-standard-calibration-with-uncertainties-for-8720D-vector-network-analyzer.pdf I noticed the 3.5 mm verification kit used was the obsolete 85053A, not the current 85053B. Is there any advantage in using that kit over the current 85053B? I was thinking of buying a verification kit, so would like to know what's the best model to buy. I'm guessing the calibration procedure for the 8720D was developed before the 85053B was available, and Agilent see no reason to update the procedure to use the current kit when the obsolete 85053A does the job. But if there are advantages in using the obsolete kit, I'll bear that in mind when looking for a kit. According to the information I can find on the current 85053B it does support the 8720 series, so on the face of it, buying an 85053B would be a better choice. Dave |
1个回答
戴夫,两人都会工作。
B套件具有无槽连接器,并且在航空公司和beatty标准上都有珠子,以帮助进行适当的机械校准并防止在测试中损坏中心传输线。 唯一需要担心的是85052B套件必须用于校准872x产品作为A使用的开槽标准,并且在8 GHz左右有模拟问题。 戴夫 以上来自于谷歌翻译 以下为原文 Dave, Both will work. The B kit had slotless connectors and had beads on both the airline and beatty standard to assist in proper mechanical alignment and to prevent damage to center transmission line in testing. The only real thing to worry about is the 85052B kit must be used in calibrating 872x products as the A used slotted standards and had moding problems around 8 GHz. Dave |
只有小组成员才能发言,加入小组>>
1844 浏览 0 评论
2739 浏览 1 评论
2640 浏览 1 评论
2449 浏览 5 评论
3458 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 22:02 , Processed in 1.315169 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1985
