嗨,
我试图在FIFO /流模式下配置LIS3DH并且有一些问题,因为数据表不是很清楚。 1)我可以将INT2配置为WaterMark中断吗?我没有看到任何选项将INT2配置为寄存器位中的中断,尽管规范似乎暗示它是可能的。我们的硬件将INT2引脚连接到GPIO,因此想知道将INT2配置为水印中断是一种选择。 2)由于我无法配置INT2,因此我继续轮询FIFO_SRC_REG的WTM位以查看是否已达到水印阈值电平(假设WTM位是要查找的位置)。但是,每当我读取FIFO_SRC_REG时,它就会变为0.我在CTRL_REG5(第6位)中启用了FIFO,并将模式设置在FIFO_CTRL_REG中。我错过了什么?此外,FIFO_SRC_REG对reg位的含义没有任何解释。 以上来自于谷歌翻译 以下为原文 Hi, I am trying to configure LIS3DH in FIFO/Stream mode and have a few questions as the data sheet is not very clear. 1) Can I configure the INT2 as the WaterMark interrupt? I don't see any option to configure INT2 as the interrupt in the register bits, although the spec seems to imply it is possible. Our hardware has the INT2 pin connected to a GPIO, hence would like to know if configuring INT2 as the watermark interrupt is an option. 2) Since I couldn't configure INT2, I went with polling the WTM bit of FIFO_SRC_REG to see if the watermark threshold level has reached (assuming WTM bit is the place to look for). However, whenever I read FIFO_SRC_REG it comes out as 0. I have enabled the FIFO in CTRL_REG5 (bit 6) and set the mode in FIFO_CTRL_REG. What am I missing? Also, FIFO_SRC_REG doesn't have any explanation on what the reg bits mean. |
1个回答
第2点快速修正。
但是,每当我读取FIFO_SRC_REG时,它就会显示为0x20(如前所述,不是0)。 FIFO似乎是空的。 以上来自于谷歌翻译 以下为原文 Quick correction on point 2. However, whenever I read FIFO_SRC_REG it comes out as 0x20 (not 0 as mentioned before). FIFO seems to be empty. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
658浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 20:36 , Processed in 0.587481 second(s), Total 39, Slave 32 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2777
