电子发烧友论坛|
你好
我试图在FIFO模式下使用LIS3DH并启用滤波器。 在此模式下,X轴和Y轴值得到一些正常值(它们在-10和+10之间振荡)但Z轴值似乎绕过滤波器模式,Z轴给出例如-616如果我禁用FIFO和过滤器,则不是Z轴的值。 这是LIS3DH的某种限制吗?或者我在初始化时做错了什么。 在我的初始化代码中,寄存器使用以下值初始化: CTRL_REG1 = 0x17 CTRL_REG2 = 0x88 CTRL_REG3 = 0x00 CTRL_REG4 = 0x40 CTRL_REG5 = 0x40 CTRL_REG6 = 0x00 FIFO_CTRL_REG = 0x40 谢谢 阿图尔维埃拉 以上来自于谷歌翻译 以下为原文 Hello I am trying to use the LIS3DH in FIFO Mode with Filter enabled. In this mode, the X-Axis, and Y-Axis values get some normal values (they oscillate between -10 and +10) but the Z-Axis value seems to have a bypass to the filter mode, the Z-Axis gives for example -616 witch is not the value for Z-Axis if i disable FIFO and Filter. Is this some kind of limitation of LIS3DH? or am i making something wrong at initialization. In my initialization code the registers are initialized with the following values: CTRL_REG1 = 0x17 CTRL_REG2 = 0x88 CTRL_REG3 = 0x00 CTRL_REG4 = 0x40 CTRL_REG5 = 0x40 CTRL_REG6 = 0x00 FIFO_CTRL_REG = 0x40 Thank You Artur Vieira |
5个回答
嗨,
尽管使用FIFO,HP-FILTER和Z轴,LIS3DH似乎存在限制 它没有记录(但是?)。我从支持团队得到的答复是,如果需要这个功能,他们建议使用LIS2DH。 以上来自于谷歌翻译 以下为原文 Hi, There seem to bee a limitation in LIS3DH regarding using FIFO, HP-FILTER and the Z-axis even though it is not documented (yet?). The reply I got from the support team was that if this functionality was require the they suggested using the LIS2DH. |
你好
感谢您的反馈。 在那里我重新设计PCB,因为LIS2D和LIS3D之间的足迹不一样。 谢谢 以上来自于谷歌翻译 以下为原文 Hello thanks for the feedback. There i go redesign the PCB, since the footprint is not the same between LIS2D and LIS3D. thanks |
请注意我还没有使用LIS2DH,并且可以在那里不确认HP + FIFO配置实际在Z轴上工作,并且无法找到和其他确认来源。
以上来自于谷歌翻译 以下为原文 Please notice that I have not yet worked with the LIS2DH, and can there for not confirm that the HP+FIFO configuration actual works on the Z-axis, and can't find and other source of confirmation on this. |
你好
如果LIS2DH对此类应用有任何问题,我已经向当地的ST经销商询问了。 我在等他的确认。 谢谢 以上来自于谷歌翻译 以下为原文 Hi I have asked to my local ST distributor if the LIS2DH has any problem for this kind of application. I am waiting for his confirmation. Thanks |
你好
只是为了更新。 我得到ST的确认,当使用FIFO + HP-Filter和Z-Axis时,LIS3DH存在问题。 还得到确认,LIS2没有遇到这个问题。 以上来自于谷歌翻译 以下为原文 Hi Just to update. I get the confirmation from ST that there is a problem with LIS3DH when using FIFO + HP-Filter and Z-Axis. Also get the confirmation, that LIS2 does not suffer from this problem. |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
940浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-1 21:34 , Processed in 0.766928 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2632
