大家好,我一直在尝试安装ISE Webpack 9.2和10.1,当它正在安装时,没有问题,当我启动一个新项目时会出现问题,当它发生的时候就像一个灰色窗口的错误
xilinx并没有让我看到我所有的工作,我遇到的唯一解决方案是浮动窗户,但我不喜欢在大学窗户停靠的那种方式工作,但在家里我不能停靠窗户因为 它总是发生在我告诉你的事情上.... 这是我发生的事情的图片,我希望你能帮助我解决这个问题,谢谢 以上来自于谷歌翻译 以下为原文 Hi Everyone, i've been trying to install the ISE Webpack 9.2 and 10.1, well when it is installing, there is no problem, the problem appears when i start a new project, when it happens there's like a bug in where a grey window of xilinx doesnt let me watch all my job the only solution i have met to this was to float the window, but i dont like to work in that way in the university the windows are docked, but here in home i cant dock the windows becuase it always happens what i have told you.... here is the pic of what is happening to me, i hope you can help me with this issue, Thanks |
8个回答
确定解决了问题,我在我的电脑中有windows vista主题,我改变了它正在工作,因为我现在必须做Ty所有
在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 ok solved problem, i had the windows vista theme in my pc, i changed and it is working as i has to do now Ty allView solution in original post |
听起来你可能没有在家里使用支持的操作系统。
以下是支持的操作系统列表:http://www.xilinx.com/cn/ise/ossupport/index.htm。 如果您使用的是支持的操作系统,但仍然存在问题,那么在打开Webcase时就值得了。 你用的是什么操作系统? 以上来自于谷歌翻译 以下为原文 It sounds like you are probably not using a supported OS at home. Here's the list of supported OS: http://www.xilinx.com/ise/ossupport/index.htm. If you are using a supported OS, but still have the problem then it would be worth while opening a webcase. What OS are you using? |
opppsss很好我有Windows Xp ......它认为我下载的程序必须使用itMessage由nellopez编辑于03-23-2009 11:29 AM
以上来自于谷歌翻译 以下为原文 opppsss well i have Windows Xp...... its supossed that the program that i've downloaded had to work with itMessage Edited by nellopez on 03-23-2009 11:29 AM |
嗯,Windows XP肯定是受支持的,因此问题必须由其他东西引起。
您是否可以尝试以安全模式运行PC,以便运行最少的无关进程,然后尝试运行ISE并查看行为是否继续? 可能与正在运行的其他软件存在冲突。 以上来自于谷歌翻译 以下为原文 Hmmm, Windows XP is definitely supported so the issue must be caused by something else. Can you try running your PC in safe mode so that the minimum of extraneous processes are running and then try running ISE and see if the behaviour continues? There may be conflicts with other software that is running. |
好吧,让我检查生病尝试安全模式,如果不是问题,我可能会自杀LOL,好吧,但我不知道该怎么做,我需要该程序,我怀疑这个问题几乎是不可能的......唯一的
程序,我认为它可能会像它的杀毒软件....卡巴斯基2009年,这将是问题???? 以上来自于谷歌翻译 以下为原文 ok, let me check ill try with the safe mode, and if it is not the problem i may kill myself LOL, well but i dont know what to do, i need that program i whit that issue almost impossible.... the only program that i think it may do something like that its the Antivirus.... Kaspersky 2009, would that be the problem???? |
确定安全模式测试,这里窗口出现停靠,所以请告诉我哪个程序使他ISE工作错误....我不知道哪一个可能...谢谢
以上来自于谷歌翻译 以下为原文 ok tested with the safe mode and here the window appears docked, so please tell me which program is making he ISE work wrong.... i have no idea which one could be... thanks |
以上来自于谷歌翻译 以下为原文 ok solved problem, i had the windows vista theme in my pc, i changed and it is working as i has to do now Ty all |
只有小组成员才能发言,加入小组>>
2266 浏览 7 评论
2671 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2159 浏览 9 评论
3232 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2301 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
551浏览 1评论
1620浏览 1评论
121浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2271浏览 0评论
589浏览 0评论
GMT+8, 2024-8-10 11:20 , Processed in 1.311880 second(s), Total 92, Slave 75 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
