扫一扫,分享给好友
您好,我正在尝试使用82357B USB / GPIB连接器将我的Keithley 2425数字源表与PC(Win XP)连接。
我可以通过安捷伦连接专家连接仪器,并说明:“监听器响应,但没有完成识别查询”和“*连接到:GPIB0 :: 17 :: INSTR”试图发送* IDN? 命令总是以:! VI_ERROR_TMO:发生超时Visa ErrorCode:0xBFFF0015(-1073807339)。 还试图使用ID? 命令给出了相同的错误消息。 有人对我的问题有所了解吗? 提前多多谢谢! 以上来自于谷歌翻译 以下为原文 Hello, I am trying to connect my Keithley 2425 SourceMeter with a PC (Win XP) using the 82357B USB/GPIB connector. I can connect the instrument via the Agilent Connection Expert and it is stated: "A listener responds, but no identification query was done" and "* Connected to: GPIB0::17::INSTR" Trying to sent the *IDN? command always ends up with: ! VI_ERROR_TMO: A timeout occurred Visa ErrorCode: 0xBFFF0015 (-1073807339). Also trying to use the ID? command gave the same error message. Does anybody have an idea for my problem? Thanks lots in advance! |
1个回答
我猜它不响应* IDN?
命令。 我没有手册,但规格提到SCPI 1996和_does_包括* IDN? 但我仍然认为这意味着必须实施。 它当然没有指定IEEE488.2,这意味着它应该响应。 您应该能够从用户手册中验证该假设。 假设是这样,没有问题! VEE正在发送* IDN? (它询问是否可以先发送它)并且因为仪器没有回复而超时。 只需忽略错误消息并尝试编程! 我的建议是先尝试发送一个[简单]命令,例如 设置电压输出并检查它是否符合您的预期,然后您可以确定完成您需要它完成工作所需的所有命令。 HTH 以上来自于谷歌翻译 以下为原文 I'm guessing it doesn't respond to the *IDN? command. I don't have the manual however the specs mention SCPI 1996 and that _does_ include *IDN? but I still don't think that means it has to be implemented. It certainly doesn't specify IEEE488.2 which would have meant that it should respond. You should be able to verify that supposition from the user's manual. Assuming that to be the case, there is no problem! VEE is sending *IDN? ( it asks if it can send it first ) and is timing out because the instrument is not replying. Simply ignore the error message and try programming it! My recommendation is to try to send it a [simple] command first e.g. set the voltage output and check it does what you expect and then you can work on determining all of the commands required to do the job you need it to do. HTH |
只有小组成员才能发言,加入小组>>
971 浏览 0 评论
2250 浏览 1 评论
2028 浏览 1 评论
1907 浏览 5 评论
2772 浏览 3 评论
753浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
548浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
642浏览 0评论
2430浏览 0评论
1486浏览 0评论
GMT+8, 2024-9-5 21:21 , Processed in 1.271238 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
