嗨,我在N6700B手册中遇到了一个条款,该条款规定“模块必须彼此相邻安装,从插槽1开始。不要在模块之间留下任何空插槽......”你能解释为什么我们不被允许
只需将1个模块放在插槽2或插槽3上? 那些占用2个插槽的模块怎么样?为什么这些模块能够工作? 我以为我之前在任何一个插槽都尝试过模块而且它有效。 是这样的,或者这是一个更新的固件不允许这种情况发生? 或者也许我只是想象。 谢谢。 问候,辛西娅 以上来自于谷歌翻译 以下为原文 Hi, I came across a clause in the N6700B manual which states that "Modules must be installed next to one another, starting with slot 1. Do not leave any empty slots between modules..." Can you explain why we are not allowed to just put 1 module on slot 2 or slot 3? What about those modules that take up 2 slots and why are these modules able to work? I thought I have tried with modules at just any slots before and it works. Is this all the while like this or it was a newer of firmware that does not allow this to happen? Or perhaps I was just imagining. Thanks. regards, Cynthia |
1个回答
你好,你可能会想到N6705B,它是N6700大型机的板凳版本。
在N6705B中,您可以将模块放在任何插槽中。 如果您使用的是1U主机,则必须按顺序安装模块。 这是因为这需要在主机中保持适当的气流。 如果您需要更多信息,请与我们联系。 马特 以上来自于谷歌翻译 以下为原文 Hello, You might be thinking of the N6705B, the bench version of the N6700 mainframes. In the N6705B, you can put the modules in any slot. If you are using the 1U mainframe, then the modules must be installed sequentially. This is because this is required to keep the proper airflow in the mainframe. Let me know if you need any more information. Matt |
只有小组成员才能发言,加入小组>>
1063 浏览 0 评论
2302 浏览 1 评论
2089 浏览 1 评论
1963 浏览 5 评论
2834 浏览 3 评论
832浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
613浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
709浏览 0评论
1392浏览 0评论
1065浏览 0评论
GMT+8, 2024-9-28 08:22 , Processed in 1.111851 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
