电子发烧友论坛扫一扫,分享给好友
我在SCPI命令(第21页)下的快速参考中看到,有一个命令“指定仪器的远程/本地状态”。
我下载并安装了n6700 labview驱动程序,但我找不到具有此命令的驱动程序。 我需要它,因为我需要在远程模式下使用它时将电源恢复到本地。 我是否必须为此编写LabVIEW vi,或者我没有看到已经具有此命令的LabVIEW N6700系列仪器驱动程序中的vi? 以上来自于谷歌翻译 以下为原文 I see in the quick reference under SCPI commands (page 21) that there is a command that "specifies the Remote/Local state of the instrument." I downloaded and installed the n6700 LabVIEW drivers but I can't find one that has this command. I need it because I need to return the power supply back to local when done using it in remote mode. Do I have to write a LabVIEW vi for this or am I not seeing the vi in the LabVIEW N6700 series instrument drivers palate that already has this command? |
1个回答
嗨,您是否担心N6702A的前面板被锁定?
编程时,N6702A的前面板不会自动锁定。 如果你看前面板,没有本地钥匙,就像我们的旧配件一样。 您是否还有其他原因希望它处于本地模式? 以上来自于谷歌翻译 以下为原文 Hi, Are you concerned about the front panel of the N6702A getting locked out? The front panel of the N6702A does not lock out automatically when you program it. If you look at the front panel, there is no local key like there is with our older supplies. Is there some other reason that you want it to be in local mode? |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 19:20 , Processed in 0.669813 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1569
