电子发烧友论坛|
嗨,我在N6700B主机中使用了两个模块(N6762A和N6784A)。
我知道查询正常(设定或编程)输出电压的命令,但我正在寻找查询电源端子实际输出电压的命令。 在远程使用时,电源输出将略大于编程电压,以补偿负载的路径损耗 - 是否有查询命令来检索更大的电压? 此外,该值是否为校准电压测量值? 谢谢,大卫 以上来自于谷歌翻译 以下为原文 Hi, I'm using two modules (N6762A & N6784A) in an N6700B mainframe. I know the command to query the normal (set or programmed) output voltage but am looking for a command to query the actual output voltage at the power supply terminals. When used in remote sense, the power supply output will be a little larger than the programmed voltage to compensate for path loss to the load - is there a query command to retrieve that larger voltage? Also, is the value retrieved a calibrated voltage measurement? Thanks, David |
3个回答
对不起,我们没有命令从输出中读回电压。
MEAS:VOLT? 命令将读回感测线末端的电压。 我们确实使用输出端的电压进行过压保护,因此我们会不断监控它,但我们没有SCPI命令来访问它。 你能告诉我你为什么喜欢这个吗? 我可以将其作为增强请求提交。编辑:MattC于2014年3月4日下午3:29 以上来自于谷歌翻译 以下为原文 I am sorry but we do not have a command to read back the voltage from the output. The MEAS:VOLT? command will read back the voltage at the end of the sense lines. We do use the voltage at the outputs for our over voltage protection so we are constantly monitoring it but we do not have a SCPI command to access it. Can you give me an idea of why you would like this? I can submit it as an enhancement request. Edited by: MattC on Mar 4, 2014 3:29 PM |
亲爱的MattC,我确实可以使用这个附加命令来直接了解任何安捷伦电源输出端的电压,并了解传感线发送时的电压。 我会用这些信息来了解一下连接的可靠性。 在进行测量并使用(V_output - V_sense)/ Current计算电阻时,该值应保持不变(如果电流不改变数十年)。 然后,当人们看到变化的电阻值时,这表明线路的可靠性受到威胁。 以上来自于谷歌翻译 以下为原文 Dear MattC, I do have a usage for this additional command to know the voltage directly at the outputs of any Agilent power supply and to know the voltage at the send of the sense lines. I would use this information to know a bit about the reliability of the connections. When doing measurements and calculating a resistance by using (V_output - V_sense) / Current, this value should remain constant (if the current does not change decades). Then when one sees a changing resistance value this indicates that the lines' reliability is at stake. |
我将此记录为N6700产品的增强请求。 谢谢! 以上来自于谷歌翻译 以下为原文 I logged this as an enhancement request for the N6700 products. Thanks! |
只有小组成员才能发言,加入小组>>
309 浏览 0 评论
1872 浏览 0 评论
2757 浏览 1 评论
2658 浏览 1 评论
2479 浏览 5 评论
1872浏览 0评论
438浏览 0评论
313浏览 0评论
/9
GMT+8, 2025-12-17 12:38 , Processed in 0.742778 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6049
