电子发烧友论坛|
我有一个真正的问题,视频不断闪烁大约一秒钟。
我删除了视频驱动程序并重新安装 - 没有效果。 接下来,我下载了英特尔4600的最新驱动程序。再次没有效果。 交换HDMI电缆和端口 - 没有乐趣。 可笑的是,它会自我修复并保持稳定,直到你将其唤醒并再次闪烁。 甚至在夜间关闭它,它正在闪烁,足以让你疯狂。 微软没有答案,希望英特尔人可能有一个解决方法。 哦,视频在其他输入上是稳定的,所以不是显示器问题。 谢谢。 JIM 以上来自于谷歌翻译 以下为原文 I am having a real problem with the video constantly flashing about once a second. I have removed the video driver and reinstalled - no effect. Next, I downloaded the latest driver for Intel 4600. Again no effect. Swapped HDMI cables and ports - no joy. The comical thing is that it will fix itself and remain stable until you wake it up and flashing starts again. Even turned it off for the night and right it is flashing enough to drive you nuts. Microsoft has no answer and hoping Intel folks might have a workaround. Oh, and video is stable on other inputs, so not a monitor problem. Thank you. JIM |
5个回答
您好Imolared12,感谢您在此社区中发布您的问题。为了让您更好地为您提供帮助,请向我提供系统支持实用程序将生成的.txt文件。
要附加文件,您必须单击响应框右下角的“附加”选项。我希望尽快收到您的回复。最好的问候,Diego S. 以上来自于谷歌翻译 以下为原文 Hello Imolared12, Thank you for posting your issue in this Community. In order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the “Attach” option on the bottom right-hand corner of the response box. I hope to hear from you soon. Best regards, Diego S. |
Imolared12:我只是想检查你是否看过以前发布的信息,以及你是否需要进一步的帮助?
有任何问题,请告诉我。 此致,英特尔技术支持 以上来自于谷歌翻译 以下为原文 Imolared12: I just wanted to check if you saw the information posted previously and if you need further assistance on this matter? Any questions, please let me know. Regards, Intel Technical Support |
根据要求附加文件。 希望你可以帮忙,因为闪烁让我疯了! 谢谢。 JIM 英特尔SSU - 9-03-2018.txt.zip 5.1 K. 以上来自于谷歌翻译 以下为原文 File attached as requested. Hope you can help as flicker is driving me nuts! Thank you. JIM |
您好Imolared12,感谢您的回复。您能否提供完整的系统型号和品牌,因为SSU报告中没有显示(出于某种原因)?希望这有帮助.Regards,Diego S. 以上来自于谷歌翻译 以下为原文 Hello Imolared12, Thank you for your response. Can you please provide us with your full system model and brand as this one is no displayed (for some reason) in the SSU report? I hope this helps. Regards, Diego S. |
jerry1978 发表于 2018-11-20 11:48 您好Imolared12,我们只是想仔细检查您是否还需要进一步的帮助。请不要犹豫与我们联系。我希望尽快收到您的回复。最诚挚的问候,Diego S. 以上来自于谷歌翻译 以下为原文 Hello Imolared12, We just wanted to double check if you still need further assistance. Please don’t hesitate on contacting us back. I hope to hear from you soon. Best Regards, Diego S. |
只有小组成员才能发言,加入小组>>
/9
GMT+8, 2025-12-2 04:40 , Processed in 0.815682 second(s), Total 82, Slave 65 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
602
