电子发烧友论坛|
我通过USB线将Agilent N5242A网络分析仪连接到我的计算机。
通过使用Agilent IVI驱动程序(AqNA),我可以通过matlab仪器控制工具箱从计算机与N5242A进行通信。 在IVI驱动程序中,有许多功能可用于控制N5242A,但我不知道必须输入函数调用的参数。 例如:function [pReceiverPortVal,pSourcePortVal] = channelmeasurementgetsparameter(obj,RepCapIdentifier)什么是obj和RepCapldentifier。 函数channelsegmentaddcenterspan(obj,RepCapIdentifier,CenterVal,SpanVal,NumberOfPointVal,IFBandwidthVal,PowerVal,TimeVal)什么是“obj,RepCapIdentifier,CenterVal,SpanVal,NumberOfPointVal,IFBandwidthVal,PowerVal,TimeVal”它们应该是什么值? AqNA,IVI驱动程序中包含许多功能。 在哪里可以找到关于哪个参数应该进入每个函数的信息,这个函数调用会出现哪种数据以及每个函数的功能是什么? 什么文件? 以上来自于谷歌翻译 以下为原文 I connected Agilent N5242A network analyzer to my computer through USB cable. I am able to communicate to N5242A from computer through MATLAB instrument control tool box by using Agilent IVI driver ( AqNA ). Inside the IVI driver, there are many functions which can be used to control the N5242A, but I don't know the parameters which have to input the function call. for example: function [pReceiverPortVal, pSourcePortVal] = channelmeasurementgetsparameter(obj, RepCapIdentifier) what is the obj, and RepCapldentifier. function channelsegmentaddcenterspan(obj, RepCapIdentifier, CenterVal, SpanVal, NumberOfPointVal, IFBandwidthVal, PowerVal, TimeVal) what are " obj, RepCapIdentifier, CenterVal, SpanVal, NumberOfPointVal, IFBandwidthVal, PowerVal, TimeVal " what value they should be? There are many function included in the AqNA, IVI drivers. where I can find the information about which parameter should go into this each function, which kind data will come out this function call and what functionality of each function? What document? |
1个回答
这是你用的司机吗?
http://www.keysight.com/main/software.jspx?ckey=1669213&lc=chi&cc=CN&nid=-11143.0.00&id=1669213如果是,1。您可以参考帮助 函数文件(但我没有在帮助文件中看到你的函数)2。你可以选择自定义安装并选择源代码,然后你就可以看到源代码 以上来自于谷歌翻译 以下为原文 Is this the driver you used? http://www.keysight.com/main/software.jspx?ckey=1669213&lc=chi&cc=CN&nid=-11143.0.00&id=1669213 If it is, 1. You can refer to the help file for the functions (but I didn't see your function in the help file) 2. You can choose custom install and select source code, then you are able to see the source code |
只有小组成员才能发言,加入小组>>
309 浏览 0 评论
1872 浏览 0 评论
2757 浏览 1 评论
2658 浏览 1 评论
2479 浏览 5 评论
1872浏览 0评论
438浏览 0评论
313浏览 0评论
/9
GMT+8, 2025-12-17 16:12 , Processed in 1.299683 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3909
