电子发烧友论坛扫一扫,分享给好友
你好
我想使用并行作业来运行P& R. 如果我的杯芯有30,那么-jobs可以配置30? launch_run -to_step opt_design -jobs号码 以上来自于谷歌翻译 以下为原文 Hello I want to used parallel jobs to running P&R. If my cup core have 30, then the -jobs can be configured 30? launch_run -to_step opt_design -jobs number |
3个回答
嗨@ quincyq2003
按任务划分的最大线程数为:•DRC报告:8•静态时序分析:8•放置:8•路由:8•物理优化:8 系统,限制为2; 对于Linux系统,默认值为8.可以使用名为general.maxThreads的参数更改限制。 要更改限制,请使用以下Tclcommand:Vivado%set_param general.maxThreads 有关详细信息,请参阅https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug904-vivado-implementation.pdf的第7页。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @quincyq2003 The maximum number of threads by task is: • DRC reporting: 8 • Static timing analysis: 8 • Placement: 8 • Routing: 8 • Physical optimization: 8 systems, the limit is 2; for Linux systems the default is 8. The limit can be changed using a parameter called general.maxThreads. To change the limit use the following Tcl command: Vivado% set_param general.maxThreads Refer to page 7 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug904-vivado-implementation.pdf for more details. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution.View solution in original post |
@ quincyq2003你甚至可以让它大于内核数量,具体取决于你拥有多少内存。
- 如果提供的信息有用,请将答案标记为“接受为解决方案”。给予您认为有用且回复的帖子。 以上来自于谷歌翻译 以下为原文 @quincyq2003 You can even make it larger than the number of cores, depending on how much memory you have. - Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. |
嗨@ quincyq2003
按任务划分的最大线程数为:•DRC报告:8•静态时序分析:8•放置:8•路由:8•物理优化:8 系统,限制为2; 对于Linux系统,默认值为8.可以使用名为general.maxThreads的参数更改限制。 要更改限制,请使用以下Tclcommand:Vivado%set_param general.maxThreads 有关详细信息,请参阅https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug904-vivado-implementation.pdf的第7页。 谢谢,维杰----------------------------------------------- ---------------------------------------------请将帖子标记为 一个答案“接受为解决方案”,以防它有助于解决您的查询。如果一个帖子引导到解决方案,请给予赞誉。 以上来自于谷歌翻译 以下为原文 Hi @quincyq2003 The maximum number of threads by task is: • DRC reporting: 8 • Static timing analysis: 8 • Placement: 8 • Routing: 8 • Physical optimization: 8 systems, the limit is 2; for Linux systems the default is 8. The limit can be changed using a parameter called general.maxThreads. To change the limit use the following Tcl command: Vivado% set_param general.maxThreads Refer to page 7 of https://www.xilinx.com/support/documentation/sw_manuals/xilinx2016_4/ug904-vivado-implementation.pdf for more details. Thanks,Vijay -------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helped resolve your query. Give kudos in case a post in case it guided to the solution. |
只有小组成员才能发言,加入小组>>
3118 浏览 7 评论
3407 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2874 浏览 9 评论
3966 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3057 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1326浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1168浏览 1评论
/9
GMT+8, 2025-12-2 20:28 , Processed in 0.707813 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5978
