电子发烧友论坛|
大家好,我正在使用SPC560D40L1微控制器并试图将DSPI1配置为从机模式。我正在使用SPC5studio进行配置。我已经设置了引脚方向和OBE和IBE以及CS的WPS和WPE配置,并改变了时钟和CS的方向,我根据数据表使用了CS0_1引脚来启用从模式。我需要处理其他任何设置吗?当我在代码执行期间看到DSPI 1的重新设置设置时,它显示通道始终处于主模式。有谁知道我需要如何设置DSPI通道的从机模式?在此先感谢Preetha。
以上来自于谷歌翻译 以下为原文 Hi Everyone, I am using SPC560D40L1 micro controller and trying to configure DSPI1 to be in slave mode. I am using SPC5studio to make the configuration. I have set pin directions and OBE and IBE along with WPS and WPE configurations for the CS and changed directions for the clock and CS, I have made use of the CS0_1 pin as per the datasheet for enabling slave mode. Is there any other settings that i need to take care of? When i see the resgister settings of DSPI 1 during code execution it shows the channel is always in master mode. Does anyone know how i need to set the slave mode for the DSPI channel? Thanks in advance Preetha. |
1个回答
你好 ,
您是否将相应的MSTR设置为0? MSTR 主/从模式选择 将DSPI配置为主模式或从模式。 0 DSPI处于从机模式 1 DSPI处于主模式中,对于应该配置的pinmap视点 在从机模式下,CS0_x信号是从机选择输入信号,允许SPI主机发送 选择DSPI作为传输目标。 CS0_x必须配置为输入和 拉得很高。如果正在使用内部上拉,则相关的相应位 必须设置SIU_PCR(SIU_PCR [WPE = 1],[WPS = 1])。最好的祝福 二万 以上来自于谷歌翻译 以下为原文 Hello , Did you set the corresponding MSTR to 0 ? MSTR Master/slave mode select Configures the DSPI for master mode or slave mode. 0 DSPI is in slave mode 1 DSPI is in master modeAnyway , for the pinmap point of view you should configure In slave mode, the CS0_x signal is a slave select input signal that allows an SPI master to select the DSPI as the target for transmission. CS0_x must be configured as input and pulled high. If the internal pullup is being used then the appropriate bits in the relevant SIU_PCR must be set (SIU_PCR [WPE = 1], [WPS = 1]). Best regards Erwan |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 03:04 , Processed in 0.674427 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1602
