电子发烧友论坛|
ICD4网页表明,相关的外部电源工具是AC2014。DigiKy和MuleR都表示该部件的直流插头为2.1mm的ID×5.5mm OD。我买了一个同样规格的电源,但插头不适合ICD4。我刚刚在Microchip直接找到,AC2014是一个替代的FACAC202039。在DigiKEY上的ANAC162039是2.5mm的ID。您是否能够确认AC2014是ICD4的正确电源,如果是的话,DC插头的尺寸是多少?
以上来自于百度翻译 以下为原文 The ICD4 webpage indicates that the related tool for external power is AC002014. Both digikey and mouser indicate that the DC plug for this part is 2.1mm ID x 5.5mm OD. I bought a similar power supply with the same specs but the plug does not fit into the ICD4. I just found on Microchip Direct that the AC002014 is a replacement for AC162039. And AC162039 on digikey is 2.5mm ID... Would you be able to confirm that the AC002014 is the correct power supply for the ICD4 and, if so, what the dimensions of the DC plug is? |
2个回答
YESAC2014是正确的ON.AC02014-9V壁挂电源“本产品是一个9V,110-220V的通用电源,具有适用于北美洲、欧洲和亚洲大多数国家的电源插座的适应性插头。最大输出电流为1.3A,输出插口为5mm,中心为正。该电源可与MPLAB ICD 2、Explorer 16(DM24001)、PICSTARP PLUS(DV00 300 1)、PROMART II(DV00 700 3)和许多其他演示板一起使用。它取代了我们的标准9V电源(AC162039)。“对于一个微芯片资源管理器16板,我使用的是HASTRON电源,HES10-09007-07.7它正在工作。但是我不建议用ICD4使用它,它得到9V,但是只有0.75杰克接缝是2.1mm×5.5mm。但是也许有人带了一个。AC2014
以上来自于百度翻译 以下为原文 Yes AC002014 is the correct one. AC002014 - 9V Wall Mount Power Supply "This product is a 9V, 110-220V universal power supply with adaptable plugs suitable for electrical outlets in most countries in North America, Europe, and Asia. The maximum output current is 1.3A. The output jack is 5mm and center-positive. This power supply can be used with the MPLAB ICD 2, Explorer 16 (DM240001), PICSTART Plus (DV003001), the PRO MATE II (DV007003), and many of our other demo boards. It replaces our standard 9V power supply (AC162039)." For a Microchip Explorer 16 Board I am using the a Hitron power supply, the HES10-09007-0-7. It is working. But I would not recommend to use it with ICD4, it got 9V but only 0.75A The Jack seams to be 2.1mm x 5.5mm. But perhaps there is someone with a AC002014 |
嗨,我没有一个ICD4,但是我有一个“真正的冰功率监视器”(AC24400),并且包含在盒子里,你也可以在“电力监视器用户指南,附录C”上读到,有一个AC2014,我可以确认,它是5.5mm×2.5mm。
以上来自于百度翻译 以下为原文 Hi, I don't have an ICD4, but I have a "Real ICE Power Monitor" (AC244008) and, included in the box, as you can also read on the "Power Monitor User's guide, Appendix C", there is an AC002014 which, I can confirm, is 5.5mm x 2.5mm. Guglielmo |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
454 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3529 浏览 3 评论
1121浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1094浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
872浏览 1评论
460浏览 0评论
/9
GMT+8, 2025-12-1 16:19 , Processed in 0.729931 second(s), Total 73, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4869
