电子发烧友论坛|
当我尝试使用绝对操作连接任何其他浮点运算时,我遇到了这个问题。
它看起来与时钟有关,但我找不到如何启用它。 以上来自于谷歌翻译 以下为原文 I'm having this problem when I try to connect any other floating point operation with Absolute operation. It looks an issue with the clock but I'm cannot find how to enable it. |
2个回答
嗨rbopq,
查看错误消息,S_AXIS_A的频率中的零值大于M_AXIS_RESULT上的零值,因此S_AXI Freqis 10高出十倍。 ThanksAidan -------------------------------------------------- -------------------------------------------------- --------------请将答案标记为“接受为解决方案”,如果这回答了您的问题,请给予您认为有用的帖子,并可以帮助其他用户------- -------------------------------------------------- -------------------------------------------------- ------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi rbopq, Looking at the error message the amount of Zeroes in the Freq of S_AXIS_A is greater than that on M_AXIS_RESULT so the S_AXI Freq is 10 ten times higher. Thanks Aidan ------------------------------------------------------------------------------------------------------------------ Please mark the Answer as "Accept as solution" if this answered your question Give Kudos to a post which you think is helpful and may help other users ------------------------------------------------------------------------------------------------------------------View solution in original post |
嗨rbopq,
查看错误消息,S_AXIS_A的频率中的零值大于M_AXIS_RESULT上的零值,因此S_AXI Freqis 10高出十倍。 ThanksAidan -------------------------------------------------- -------------------------------------------------- --------------请将答案标记为“接受为解决方案”,如果这回答了您的问题,请给予您认为有用的帖子,并可以帮助其他用户------- -------------------------------------------------- -------------------------------------------------- ------- 以上来自于谷歌翻译 以下为原文 Hi rbopq, Looking at the error message the amount of Zeroes in the Freq of S_AXIS_A is greater than that on M_AXIS_RESULT so the S_AXI Freq is 10 ten times higher. Thanks Aidan ------------------------------------------------------------------------------------------------------------------ Please mark the Answer as "Accept as solution" if this answered your question Give Kudos to a post which you think is helpful and may help other users ------------------------------------------------------------------------------------------------------------------ |
只有小组成员才能发言,加入小组>>
3141 浏览 7 评论
3435 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2897 浏览 9 评论
4097 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
3082 浏览 15 评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
1359浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
1196浏览 1评论
/9
GMT+8, 2025-12-11 21:58 , Processed in 0.580380 second(s), Total 46, Slave 39 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7818
