你好
我想通过vivado 2016.4生成位文件(综合和实现完成),但报告此消息: 我该如何解决这个问题? 命令:write_bitstream -force -no_partial_bitfile PRC3922.bit 试图获得功能“实施”和/或设备“xcvu440”的许可 信息:[通用17-349]获得功能'实施'和/或设备'xcvu440'的许可 信息:[通用17-86]您的实施许可证在3天后到期 信息:[通用17-1223]您的许可证的版本限制为“2017.04”,并将在-17天后到期。 版本限制到期意味着,尽管您可以继续使用此许可证的当前版本的工具或IP,但您将没有资格获得任何更新或新版本。 运行DRC作为命令write_bitstream的前提条件 信息:[DRC 23-27]运行8个线程的DRC /../vivado_2016.04/Vivado/2016.4/bin/loader:第179行:8259已被杀“$ RDI_PROG”“$ @” [2017年5月17日星期三03:21:38] impl_1完成了 wait_on_run:时间:cpu = 00:00:03; 逝去了= 13:08:58。 内存(MB):峰值= 11564.246; 增益= 0.000; free physical = 23997; free virtual = 36049 信息:[共同17-206] 2017年5月17日星期三03:22:28退出Vivado .. 以上来自于谷歌翻译 以下为原文 Hello I want to generator bit file by vivado 2016.4(synthesis and Implement is complete), but report this message: How do i can resolve this issue? Command: write_bitstream -force -no_partial_bitfile PRC3922.bitAttempting to get a license for feature 'Implementation' and/or device 'xcvu440'INFO: [Common 17-349] Got license for feature 'Implementation' and/or device 'xcvu440'INFO: [Common 17-86] Your Implementation license expires in 3 day(s)INFO: [Common 17-1223] The version limit for your license is '2017.04' and will expire in -17 days. A version limit expiration means that, although you may be able to continue to use the current version of tools or IP with this license, you will not be eligible for any updates or new releases.Running DRC as a precondition to command write_bitstreamINFO: [DRC 23-27] Running DRC with 8 threads/../vivado_2016.04/Vivado/2016.4/bin/loader: line 179: 8259 Killed "$RDI_PROG" "$@"[Wed May 17 03:21:38 2017] impl_1 finishedwait_on_run: Time (s): cpu = 00:00:03 ; elapsed = 13:08:58 . Memory (MB): peak = 11564.246 ; gain = 0.000 ; free physical = 23997 ; free virtual = 36049INFO: [Common 17-206] Exiting Vivado at Wed May 17 03:22:28 2017.. |
2个回答
嗨@ quincyq2003,
尝试在运行之前设置多线程asset_param general.maxThreads 1。 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉------------------------- -------------------------------------------------- -------------------- 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi @quincyq2003, Try by setting the Multi-threading as set_param general.maxThreads 1 before the runs. Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- View solution in original post |
嗨@ quincyq2003,
尝试在运行之前设置多线程asset_param general.maxThreads 1。 问候,Prathik ----------------------------------------------- ------------------------------------------------请注明 帖子作为答案“接受为解决方案”,以防它有助于解决您的查询。帮助回答 - >给予赞誉------------------------- -------------------------------------------------- -------------------- 以上来自于谷歌翻译 以下为原文 Hi @quincyq2003, Try by setting the Multi-threading as set_param general.maxThreads 1 before the runs. Regards, Prathik ----------------------------------------------------------------------------------------------- Please mark the post as an answer "Accept as solution" in case it helps to resolve your query. Helpful answer -> Give Kudos ----------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2427 浏览 7 评论
2828 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2295 浏览 9 评论
3377 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2467 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
1269浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
592浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
455浏览 1评论
2010浏览 0评论
736浏览 0评论
GMT+8, 2024-12-26 06:40 , Processed in 1.176584 second(s), Total 50, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
