电子发烧友论坛|
您好,我想监测7个电压:0.85伏,0.95V,0.9V-1.1V,1.5V,1.8V,2.5V和3.3V。我正在看PSOC5设备,并想知道这是否是一个很好的选择,以监测这些电压。有人能对此发表评论,还是提出一个更好的设备?我也在看Altera的Max设备,但我宁愿使用微控制器。
谢谢, 乔 以上来自于百度翻译 以下为原文 Hello, I'm looking to monitor 7 voltages: 0.85V, 0.95V, 0.9V - 1.1V, 1.5V, 1.8V, 2.5V and 3.3V. I was looking at the PSoc5 devices and was wondering if this would be a good choice to monitor these voltages. Can anyone comment on this or suggest a better device? I was also looking at Altera's MAX10 device but I would rather use a microcontroller. Thanks, Joe |
8个回答
这当然是一个问题。
频率-需要多少值被采样/ s? 精度-需要多少位 最后,你想用这7个价值观做什么? 鲍勃 以上来自于百度翻译 以下为原文 This is of course a question of Frequency - How often need the values be sampled/s Precision - How many bits are needed and last: What do you want to do with the 7 values? Bob |
鲍勃, 你好,如何用毫伏分辨率测量每秒钟,并通过SPI将这些值发送到LCD显示器。 乔 以上来自于百度翻译 以下为原文 Bob, Hello, how about measure every second with a resolution of millivolts and send the values to a LCD display over SPI. Joe |
没问题。拿起CY8CKIT-059并开始。 快乐编码 鲍勃 以上来自于百度翻译 以下为原文 No problem at all. get hands on a CY8CKIT-059 and start. Happy coding Bob |
鲍勃, 非常感谢你的建议。PSoC6比PSOC5在电压监测这一课题上更好吗? 谢谢, 乔 以上来自于百度翻译 以下为原文 Bob, Thank you very much for the suggestion. Is the PSoc6 a better choice than the PSoc5 on this topic of voltage monitoring? Thanks, Joe |
PSoC6有点复杂,因为它包含两个可以单独编程的MPU。对于您的要求,PSOC5就足够了。即使是PSoC 4也足以满足您的需求。 鲍勃 以上来自于百度翻译 以下为原文 The PSoC6 is a bit more complicated because it contains two MPUs which can be programmed individually. For your requirements a PSoC5 will be sufficient. Even a PSoC 4 would be enough to handle your requirements. Bob |
再次感谢! 以上来自于百度翻译 以下为原文 Thanks again! |
鲍勃, 嗨,还有一个问题要问你。我正在看PSoC 5LP系列微控制器的数据表,在第4页,它们在模拟系统块中有4个运算放大器。我的问题是,模拟系统可以采样任何GPIO引脚吗?或者只有具有opopxp/n的引脚,所以意味着我只能监视4个信号。 谢谢, 乔 以上来自于百度翻译 以下为原文 Bob, Hi, one more question for you. I'm looking at the datasheet for the PSoc 5LP family of microcontrollers and on page 4 they have 4 opamps in the Analog System block. My question is, can the Analog System sample any of the GPIO pins? Or only the pins that have OPAMPxp/n, so that means I can only monitor 4 signals. Thanks, Joe |
lingjianghui 发表于 2018-10-31 14:08 您可以检查PoC5LP中的创建者可用的ADC组件的代码示例 以上来自于百度翻译 以下为原文 You can check the Code examples for ADC component available in Creator for PSoC5LP |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7088 浏览 0 评论
2474 浏览 1 评论
2166 浏览 1 评论
4031 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
710浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7962浏览 2评论
/9
GMT+8, 2025-12-2 02:38 , Processed in 0.995867 second(s), Total 86, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1055
