电子发烧友论坛|
你好,
我现在设法从我的温度传感器读取模拟值,我现在想知道如何将该值(3643)转换为温度?我没有看到任何类型的公式如何用Vref(参考电压)计算该值以及我如何自己获得输入电压。你有什么想法我能做到这一点吗? 最好的祝福 #adc-vrefint #adc 以上来自于谷歌翻译 以下为原文 Hello, i now managed to reada analog value from my temperature sensor and i am now wondering how i can convert that value (3643) to a temperature? I didn't see any kind of formula how the value is calculated with Vref (reference Voltage) and how i can get the input voltage on its own. Do you have any ideas how i can do this? Best regards #adc-vrefint #adc |
2个回答
请参阅多维数据集中的示例,例如STM32Cube_FW_L4_V1.6.0 Projects STM32L476RG-Nucleo Examples_LL ADC ADC_TemperatureSensor
可以在ll_adc lib中获得ADC值到温度的计算:__LL_ADC_CALC_TEMPERATURE 有关理论,请参阅AN3964 http://www.st.com/content/ccc/resource/technical/document/application_note/b9/21/44/4e/cf/6f/46/fa/DM00035957.pdf/files/DM00035957.pdf/jcr:内容/翻译/ en.DM00035957.pdf 希望它有所帮助 奥利维尔 以上来自于谷歌翻译 以下为原文 Refer to exemple in Cube eg STM32Cube_FW_L4_V1.6.0ProjectsSTM32L476RG-NucleoExamples_LLADCADC_TemperatureSensor Computation of ADC value to temperature is available in ll_adc lib : __LL_ADC_CALC_TEMPERATURE Refer to AN3964 for theory http://www.st.com/content/ccc/resource/technical/document/application_note/b9/21/44/4e/cf/6f/46/fa/DM00035957.pdf/files/DM00035957.pdf/jcr:content/translations/en.DM00035957.pdf Hope it help Olivier |
你好,我们又见面了
Gustamko.Master 关于STM32的第一个答案的道歉 对于STM8,相关软件示例和应用说明可在此处获得 https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/stm8-embedded-software/stsw-stm8070.license%3d1485523987494.html http://www.st.com/content/ccc/resource/technical/document/application_note/46/07/39/dd/1d/f8/46/7a/DM00028336.pdf/files/DM00028336.pdf/jcr:内容/翻译/ en.DM00028336.pdf 注意:原始帖子包含大量线程对话,只能迁移到第9级 以上来自于谷歌翻译 以下为原文 Hi again Gustamko.Master Apology for my first answer about STM32 For STM8 relevant software exemple and application note are available here https://my.st.com/content/my_st_com/en/products/embedded-software/mcus-embedded-software/stm8-embedded-software/stsw-stm8070.license%3d1485523987494.html http://www.st.com/content/ccc/resource/technical/document/application_note/46/07/39/dd/1d/f8/46/7a/DM00028336.pdf/files/DM00028336.pdf/jcr:content/translations/en.DM00028336.pdf Note: the original post contained a large number of threaded conversations and was only able to be migrated to the 9th level |
只有小组成员才能发言,加入小组>>
stm32mp157的异核通信的rpmsg_sdb的m4固件和a7驱动该如何编写?
1453 浏览 0 评论
stm32f103用freertos对一个采样率为1kHz的传感器,进行采样,数据出差
1502 浏览 0 评论
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
3649 浏览 1 评论
3842 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
2461 浏览 1 评论
STM32H7打开DCache后,出现了串口接收信息为空的现象,是哪里出了问题?
727浏览 5评论
用NANO STM32F103RBT6的开发板烧录不了是哪里出了问题?
661浏览 5评论
710浏览 5评论
外部中断触发类型为双边沿触发,进入中断回调后有什么办法判断该边沿是上升沿还是下降沿?
941浏览 5评论
STM32L071CBT6低温环境下无法正常工作是什么原因引起的?
745浏览 5评论
/9
GMT+8, 2025-12-2 06:11 , Processed in 0.880423 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1473
