错误是:
[Designutils 20-1448]无法读取存档'E:/Project/Vivado/EES326_50T_test_2015p4_v01/EES326_50T_test_2015p4_v01.runs/impl_2/.Xil/Vivado-8080-Johnson-PC/dcp/m4_FPGA_top.incr':输入流错误。 存档不包含预期的字符串或已损坏。 运行实现时会出现此错误; 我使用vivado 2015.2; 我不知道原因以及如何解决它; 请帮帮我;谢谢 以上来自于谷歌翻译 以下为原文 The error is: [Designutils 20-1448] Failed to read archive 'E:/Project/Vivado/EES326_50T_test_2015p4_v01/EES326_50T_test_2015p4_v01.runs/impl_2/.Xil/Vivado-8080-Johnson-PC/dcp/m4_fpga_top.incr': input stream error. The archive does not contain an expected string or is corrupted. This error appears when i run implementation; I use vivado 2015.2; i don't know the reason and how to solve it; please help me;Thanks |
6个回答
嗨,从错误消息,这看起来像腐败档案。您可以尝试再次解压缩/解压缩您的项目并尝试打开吗?另外请确保您解压缩您的项目的位置应该有适当的读/写permisssions.Thanks,
佳日 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 Hi, From the error message this looks like corrupt archive. Can you please try to unarchive/unzip your project again and try to open? Also please make sure that the location you are unzipping your project should have proper read/write permisssions. Thanks, YashView solution in original post |
@yzaxin,
你能给我们一些更多信息吗? 您是否尝试使用dcp文件并运行place& 路线吗? 如果可能,您可以尝试在Vivado 2016.2中实现该设计吗? --Syed -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @yzaxin, Can you give us some more information? Are you trying to use dcp file and run place & route on it? If possible can you try implementing the design in Vivado 2016.2? --Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
佳日 以上来自于谷歌翻译 以下为原文 Hi, From the error message this looks like corrupt archive. Can you please try to unarchive/unzip your project again and try to open? Also please make sure that the location you are unzipping your project should have proper read/write permisssions. Thanks, Yash |
我没有vivado 2016.2
这个项目是用vivado 2015.4构建的,当我用vivado 2015.2重建项目时,出现了错误。 我发现文件夹“EES326_50T_test_2015p4_v01 / EES326_50T_test_2015p4_v01.runs / impl_2 / .Xil /”为空,存档“m4_fpga_top.incr”不存在。 所以我想知道这个文件的效果,以及如何构建它。 以上来自于谷歌翻译 以下为原文 I dont have vivado 2016.2 This project was built with vivado 2015.4 and when i rebuilt the project with vivado 2015.2,the error appeared. I found the folder "EES326_50T_test_2015p4_v01/EES326_50T_test_2015p4_v01.runs/impl_2/.Xil/" is empty, the archive "m4_fpga_top.incr" did not exist. So I want to know the effect of this file, and how to build it. |
@yzaxin,
您能否分享一下解决问题的步骤。 是由于corrput文件还是由于读/写权限? 它将帮助可能面临类似错误的其他用户。 问候,赛义德 -------------------------------------------------- -------------------------------------------请注意 - 请标记答案 如果提供的信息有用,请“接受为解决方案”。给予您认为有用并回复导向的帖子。感谢Kudos .------------------------ -------------------------------------------------- ------------------- 以上来自于谷歌翻译 以下为原文 @yzaxin, Can you please share the steps followed to resolve the issue. Was it due to corrput file or due to read/write permission? It will help other users who might face similar error. Regards, Syed --------------------------------------------------------------------------------------------- Kindly note- Please mark the Answer as "Accept as solution" if information provided is helpful. Give Kudos to a post which you think is helpful and reply oriented. --------------------------------------------------------------------------------------------- |
只有小组成员才能发言,加入小组>>
2322 浏览 7 评论
2734 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2217 浏览 9 评论
3295 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2369 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
655浏览 1评论
请问vc707的电源线是如何连接的,我这边可能出现了缺失元件的情况导致无法供电
463浏览 1评论
求一块XILINX开发板KC705,VC707,KC105和KCU1500
222浏览 1评论
669浏览 0评论
1861浏览 0评论
GMT+8, 2024-10-1 09:33 , Processed in 1.164937 second(s), Total 57, Slave 50 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
