我想知道,将NMD-2.4mm公连接器(如我的PNA上的端口)连接到普通的2.4mm电缆或适配器的正确步骤是什么?
NMD 2.4mm公连接器应该与普通的2.4mm连接器兼容,我从个人经验中知道你可以将它们连接在一起,这就是为什么它们有内螺纹。 对于NMD 2.4mm,建议的扭矩为12in-lbs,而对于正常的2.4mm,则为8 in-lbs。 似乎扭矩的合适原因是将扭矩扳手放在NMD 2.4mm公连接器连接螺母上并保持2.4mm适配器的静止状态。 我需要一个.750“的特殊扭矩扳手,以便安装在NMD侧和8英寸 - 磅,还是可以使用普通的12英寸 - 磅扳手? 以上来自于谷歌翻译 以下为原文 I'm wondering, what is the correct procedure is for connecting a NMD-2.4mm male connector (like the ports on my PNA have) to a normal 2.4mm cable or adapter? The NMD 2.4mm male connectors are supposed to be compatible with normal 2.4mm connectors, and I know from personal experience you can connect them together and that is why they have the inner threads. The recommended torque for an NMD 2.4mm is 12in-lbs, and for a normal 2.4mm it is 8 in-lbs. It seems that the proper why to torque is to put the torque wrench on the NMD 2.4mm male connector coupling nut and hold the 2.4mm adapter still. Do I need a special torque wrench that is .750" to fit on the NMD side and 8 in-lbs or can I use the normal 12 in-lbs wrench? |
1个回答
没关系,我得到了一些错误的信息。
NMD使用20毫米扳手,扭矩为8英寸 - 磅。 以上来自于谷歌翻译 以下为原文 Never mind, I got some misinformation. The NMD uses a 20mm wrench and torque is 8 in-lb. |
只有小组成员才能发言,加入小组>>
1065 浏览 0 评论
2302 浏览 1 评论
2089 浏览 1 评论
1963 浏览 5 评论
2834 浏览 3 评论
833浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
614浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
711浏览 0评论
1395浏览 0评论
1067浏览 0评论
GMT+8, 2024-9-28 18:12 , Processed in 1.490048 second(s), Total 79, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
