电子发烧友论坛|
嗨,我们想用一个AtWiC1500模块启动一个新的项目。我已经阅读了一些关于这些模块固件升级的主题,但是我不确定我是否理解它。有两种方法来升级ATWIN 1500∶1的固件。使用UTWC1500的UART连接到带有USB串行转换器的PC。2。作为一个OTA升级与SPI连接从ATWIc到PIC。这是正确的吗?你喜欢哪种方式?为什么?我必须遇到什么设计考虑?谢谢!
以上来自于百度翻译 以下为原文 Hi, we want to start a new project with an ATWINC1500 Module. I've read some topics about the firmware upgrade of these modules but i'm not sure if i understand it right. There are two ways to upgrade the firmware of the ATWINC1500: 1. With UART connection from ATWINC1500 to a PC with a USB-Serial Converter. 2. As an OTA Upgrade with SPI connection from ATWINC to a PIC. Is this right? Which way would you prefer and why? What design considerations must i met? Thanks! |
3个回答
嗨,Volker,我发现这个帖子有助于解决固件升级相关的问题,我也分享了我的解决方案。http://www. McCux.com…,m=1042949和m;
以上来自于百度翻译 以下为原文 Hi Volker, I found this post helpful for solving firmware upgrade related problem, also I have shared my solution there. http://www.microchip.com/...;m=1042949&mpage=1 |
嗨,Ravic,我读过这个帖子,但是我不确定我应该使用什么样的更新。乍看起来,UART更新似乎是最简单的方法,但是我需要一个附加的UB/UART转换器。我只需要为OTA更新的PIC连接到PIC吗?
以上来自于百度翻译 以下为原文 Hi Ravic, i have read this thread but i'm not sure what kind of update i should use. On the first sight the UART Update seems to be the easiest way but i need an additional USB/Uart Converter. Do i need only the SPI connection to the PIC for the OTA update? |
OTA升级需要所有必要的接口。这和正常手术没有什么不同。如果你正在做一个新的PCB布局,我建议你把UARTHARTXD、UARTHARRXD和GND带到一个头上。它只允许您在需要时使用批处理文件进行升级,但也提供了非常有用的调试信息,这些信息来自WiC本身。下面是调试捕获的示例(删除了一些个人信息)
以上来自于百度翻译 以下为原文 The OTA upgrade requires all the necessary interface. It is no different than a normal operation. If you are doing a new PCB layout, I'd suggest you bring UART_TXD, UART_RXD and GND to a header. It only allows you to do the upgrade using the batch file method if needed, but also provides very useful debug messages coming out of the WINC itself. Here is an example of the debug capture (with some of the personal info removed) |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 02:27 , Processed in 0.628653 second(s), Total 76, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1464
