电子发烧友论坛|
嗨,Greetings!我使用下面的自定义StupPICP32 MZ2048 EFG064 ATWIN 1500(固件版本:19.4.4)和声栈V2Y05MPLAB X V4.05MPLAB XC32 V1.44这里我已经连接到现有的WiFi网络在开放的安全模式和默认信道为'6' AtWiC1500获得成功连接到路由器然而,在一段时间后(SA)大约10-15分钟,没有任何类型的数据交换,我得到了“Wi-Fi断开”事件。我尝试在WCC1500任务中找到同样的错误代码。C“M2MyWiFixRePixOnStayeSychange”状态。其中,我发现当前状态是“M2MWiFix断开”,即0和pSTWiFiStand -Gt;U8ReleCl码。作为“0”,我不能找到任何定义为“TunuM2McCuneEngReDCORE”从“1”开始有错误代码。请帮助找出背后的原因,并解决这个问题。谢谢。
以上来自于百度翻译 以下为原文 Hi, Greetings! I am using below custom setup PIC32MZ2048EFG064 ATWINC1500 (Firmware versio: 19.4.4) HARMony Stack v2_05 MPLAB X v4.05 MPLAB XC32 V1.44 Here I have connected to existing WiFi network in open security mode and default channel as '6' ATWINC1500 get connected successfully to router however after sometime (say about 10-15 minutes with no any kind of data exchange), I gets "Wi-Fi Disconnected" event. I tried to find out the error code for the same in winc1500_task.c "M2M_WIFI_RESP_CON_STATE_CHANGED" state. Wherein I found that current state is "M2M_WIFI_DISCONNECTED" i.e. 0 and pstrWiFiState->u8ErrCode as '0' for which I am not able to find any definition as "tenuM2mConnChangedErrcode" has error codes from '1' onwards. Please help to find out the cause behind it and also to resolve this issue. Thanks in advance. With Best Regards, dalohar |
13个回答
从M2MyType。嗨,不认为你可以执行WiFi扫描操作,而它已经连接。
以上来自于百度翻译 以下为原文 From m2m_types.h typedef enum { M2M_ERR_SCAN_FAIL = ((uint8)1), /*!< Indicate that the WINC board has failed to perform the scan operation. */ M2M_ERR_JOIN_FAIL, /*!< Indicate that the WINC board has failed to join the BSS . */ M2M_ERR_AUTH_FAIL, /*!< Indicate that the WINC board has failed to authenticate with the AP. */ M2M_ERR_ASSOC_FAIL, /*!< Indicate that the WINC board has failed to associate with the AP. */ M2M_ERR_CONN_INPROGRESS, /*!< Indicate that the WINC board has another connection request in progress. */ }tenuM2mConnChangedErrcode; I don't think you can perform the WiFi scan operation while it is already connected. |
你好,AsCH0866,谢谢你的回复。请注意,我没有执行WiFi扫描,但它仍然断开。我正在尝试找出为什么会发生这种情况。你能建议一些方法/步骤来找到正确的原因吗?问候,达洛哈
以上来自于百度翻译 以下为原文 Hi aschen0866, Thanks for your reply. Please note that I am not performing WiFi scan but still it gets disconnected. I am trying figure out why this is happening. Can you please suggest some method/steps to find the correct cause? Regards, dalohar |
如果你有一个Windows 10的机器,尝试启用移动热点功能,然后让你的设备连接到热点,在“局域网连接2”界面上运行WiReSrack而不是“Wi-Fi”接口,看看捕获是否给你提示。在你的自定义板上,你有ACCES吗?S到WC1500的调试端口(Pin -14 UARTHARTXD)?它在115K BPS发出调试消息。
以上来自于百度翻译 以下为原文 If you but have a Windows 10 machine, try enabling the Mobile hotspot feature, then have your device connected to the hotspot, run Wireshark over the "Local Area Connection 2" interface instead of the "Wi-Fi" interface, and see if the capture gives you a hint. On your custom board, do you have access to the WINC1500's debug port (pin-14 UART_TXD)? It has debug messages coming out at 115K-bps. |
你好,AsCH0866,谢谢你的回复!正如您所建议的,我已经记录了Win C1500调试端口,如在日志中所提到的,它说(642460)(MEM Err)空缓冲区(642470)盘从何而来,它究竟意味着什么?请指导,问候,达洛哈
以上来自于百度翻译 以下为原文 Hi aschen0866, Thank you for your reply! As suggested by you I have logged WINC1500 debug port as mentioned below Here in log it says that (642460)(MEM ERR) NULL Buffer (642470)Disc from AP What does it really mean? Please guide. Regards, dalohar |
有人请帮忙!!!!卡住了,谢谢
以上来自于百度翻译 以下为原文 Someone please help!!! Got stuck at this point. Thanks in advance |
不使用AtWiC1500,但它看起来像一条线开始一段时间,所以前面的两行也与这个问题!搜索那个错误。
以上来自于百度翻译 以下为原文 (642460)SERR(E3) (642460)SERR(E3) (642460)(mem_alloc) Pattern (642460)(MEM ERR) NULL Buffer Not used a ATWINC1500 but it looks like the lines start with a time, so the first two line above are to do with the issue as well! Search for that error. |
嗨,你应该使用XC32的最新版本,ValueV2.05(XC32目前是V2.05)。你还应该更新你的WiC1500模块到最新的FW(19.5.2)阅读发行说明。
以上来自于百度翻译 以下为原文 Hi, You should use a more recent versions of XC32 with Harmony v2.05 (XC32 is currently v2.05). You should also update your WINC1500 module to latest FW (19.5.2) read the release notes. Regards |
你好,克里斯,谢谢你的回复。我试着去寻找那个错误,但遗憾的是我不能得到任何线索。但是我仍然会继续努力。
以上来自于百度翻译 以下为原文 Hi Chris, Thanks for your reply. I tried to search for that error but unfortunately not able to get any clue. However I will still continue my efforts on the same. Regards, dalohar |
嗨,RISC,谢谢你的回复:现在我没有19.5.2固件版本,所以我正在准备同样的。一旦我通过它将返回给你。也请你帮助我建议任何参考指南,它可以解释在ATWIN 1500系列日志中使用的术语,例如(642460)Serr(E3)(64)。2460)Serr(E3)(642460)(MeMyAlOLc)模式& 00和Gt;(642460)(MEM Err)零缓冲区,我不能得到任何相同的。
以上来自于百度翻译 以下为原文 Hi RISC, Thanks for your reply :) Currently I do not have 19.5.2 firmware version so I am preparing for the same. Once I get through it will back to you. Also can you please help me on suggesting any reference guide which can explain about the terms used in ATWINC1500 serial log e.g. (642460)SERR(E3) (642460)SERR(E3) (642460)(mem_alloc) Pattern <00> (642460)(MEM ERR) NULL Buffer As I am not able to get any for the same. Regards, dalohar |
调试日志用于Microchip/Atmel的内部开发使用。但是,如果你创建了一个技术支持票,并发送他们的日志捕获,他们可以帮助你从他们的结束。除了连接到一个开放的WiFi AP,你还做什么?你没说太多。
以上来自于百度翻译 以下为原文 The debug log is for Microchip/Atmel internal development use. However, if you create a tech support ticket, and send them the log capture, they can help you from their end. What else are you doing besides connecting to an open WiFi AP? You didn't say much. |
HI,除了连接Wi-Fi AP之外,我使用TCP客户端应用程序向服务器发送数据,它将UART接收到的数据发送到服务器。起初,它工作,但后来在某个时候,TCPIPpTCPPclitEnOPEN()在返回无效的套接字时失败,或者它仍然处于该状态或断开连接。请注意,我已经在TCPPclipse应用程序中做了一些修改,使其适合我的要求。PIPTCPPY客户端应用程序导致断开连接?请您推荐我的TCP客户端应用程序,除了Microchip HealthStor示例应用程序,这样它可以帮助我检查它是否需要一些更正。请帮助我,严重陷入这个问题!!!!问候,达洛哈
以上来自于百度翻译 以下为原文 Hi, Besides of connecting to an Wi-Fi AP, I am sending data to server using TCP Client App. Which sends data received on UART to Server. At first it works but later after sometime TCPIP_TCP_CLIENT_Open() fails as it return INVALID_SOCKET and then either it remains in that state or gets disconnected. Here please note that I have done some modifications in TCP_CLIENT_APP to make it suitable to my requirements. Is there any chance that TCPIP_TCP_CLIENT App causing for disconnections? Can you please suggest me TCP Client Application apart from Microchip Harmony Stack example applications so that it may help me to check whether it needs some corrections or not. Please help me, badly stuck in this issue!!! Regards, dalohar |
嗨,看起来最新的WiC1500固件是19.5.4,你使用哪个和声项目?WiC1500和Orth:*项目有2种类型的项目:使用WiC1500板上TCP/IP栈(不使用和声TCPIP栈)*使用WiC1500在“旁路”模式(和谐TCPIP栈)中使用的项目
以上来自于百度翻译 以下为原文 Hi, It seems in the meantime latest WINC1500 firmware is 19.5.4 Which Harmony project do you use ? There are 2 types of projects for WINC1500 and Harmony : * projects which use the WINC1500 onboard TCP/IP stack (Harmony TCPIP stack is not used) * projects which use the WINC1500 in "bypass" mode (Harmony TCPIP stack is used) Regards |
您好,请注意,我使用的是和谐的TCP/IP协议栈,即AtWiC1500在旁路
以上来自于百度翻译 以下为原文 Hi, Please note that I am using Harmony TCP/IP based stack i.e. ATWINC1500 in bypass mode Regards, dalohar |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 05:54 , Processed in 1.082942 second(s), Total 96, Slave 79 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3635
