电子发烧友论坛|
您好,我已成功为HP 16702B逻辑分析仪购买了HP 16534A 500MHz带宽数字化示波器。
我得到了一个很好的协议,并被告知触发功能由于某种原因不起作用。 我还没有在邮件中收到我的16702B,但它已经开始了。 我决定只看一下示波器模块,发现我认为缺少SMD元件。 不幸的是,板上似乎没有丝网层,所以我不知道它们是什么组件,或者它们是否应该在那里。 一个看起来像一个垫已被扯掉但似乎有一个真正接近它的通道,我想我可以使用一个小的跳线并将其焊接到通道一些如何。 如果有两个组件应该在这里(红色框是哪里?),如果有的话,有哪些组件及其值(即5.6K欧姆电阻等)? 我真的很感激。 我想补充一点,我对电子世界很陌生,对逻辑分析仪或示波器了解不多。 不确定触发是什么以及它有多重要。 但是,我对我的焊接能力非常有信心。 我有一台Weller WHA900热风返修台和一台带微型铁尖的Weller WX2数字烙铁。 谢谢! 附: - 对不起图片的质量。 我尝试使用Irfanview让它们更轻。 如有必要,我可以尝试提供更高质量的图像。 缺少SMD组件 - 破碎的Pad.JPG385.1 KBZoomed同时在2.JPG346.3 KBZoomed in both.JPG382.3 KBZoomed in some - 缺少两个SMD Comps.JPG320.8 KB 以上来自于谷歌翻译 以下为原文 Hello, I have managed to purchase an HP 16534A 500MHz bandwidth digitizing oscilloscope for my HP 16702B Logic Analyzer. I got a good deal on it and was told that the triggering function didn't work for some reason. I haven't received my 16702B in the mail yet but it's on it's way. I decided to just look around on the oscilloscope module and found what I believe are missing SMD components. Unfortunately, there doesn't appear to be a silkscreen layer on the board so I cannot tell what components they were or if they're even supposed to be there at all. One looks like a pad has been ripped off but there appears to be a via really close to it and I'm thinking I can use a small jumper wire and solder it to the via some how. Would anyone if two components are supposed to be here (where the red boxes are?) and if so, what components and their values (Ie, a 5.6K Ohm resistor, etc)? I'd really appreciate it. I'd like to add that I'm very new to the electronic world and don't know much about logic analyzers or oscilloscopes. Not really sure what triggering is and how important it is. I do however, feel very confident with my soldering abilities. I have a Weller WHA900 Hot Air rework station and a Weller WX2 digital soldering iron with a micro iron tip. Thank you! P.S. - Sorry for the quality of the pictures. I tried using Irfanview to make them lighter. I can try providing better quality images if necessary. 附件
4个回答
我忘了说,在电路板的正面,缺少的元件上面,是一个芯片,U509。
某种处理器或带有散热片的东西似乎不可移除。 看来丢失的组件属于该芯片的电路。 想知道U509用于什么? 另一个网站上的某个人有一个这样的模块触发了他的破坏。 我有一份服务手册,但不幸的是,它没有原理图/电路板布局。 他在评论中提到惠普可能会提到他所提到的CLIP(组件级信息包)。 我假设这些CLIP包含原理图和板布局? 如果是这样的话,这款HP 16534A是否仍有机会存在,或者当其他产品在2010年被销毁时,它们是否已被销毁? 如果它们确实存在,无论如何我可以得到一个这个模块的副本? 它会让这件事变得更加容易! 谢谢! 以上来自于谷歌翻译 以下为原文 I forgot to say, on the front of the board, above the missing components, is a chip, U509. Some sort of processor or something with a heatsink on it that doesn't appear to be removeable. It appears the components that are missing belong to the circuitry for that chip. An idea what U509 is used for? Someone on another site had one of these modules with triggering broken on his. I have a copy of the service manual, but unfortunately, it lacks schematics / board layouts. He mentions in his comments though that HP might of had something that he refers to has CLIPs (Component Level Information Packages). I'm assuming these CLIPs would contain the schematics and maybe board layouts? If so, is there any chance they still exist for this HP 16534A or have they been destroyed when the rest of the stuff was destroyed back in 2010? If they do exist, anyway I could get a copy of one for this module? It'd make fixing this thing a heck of alot easier! Thank you! |
gwerwfe 发表于 2018-10-23 11:24 卖给我这个16534A的非常好的男人有另一个好的,相同的型号,并拍摄了电路板(对于U509电路),果然,他的照片中有两个不在我手中的SMD帽! 它们就在垫子所在的位置。 我只需要为这两者找到价值。 知道如何解决这个问题吗? 谢谢! 以上来自于谷歌翻译 以下为原文 The very nice man who sold me this 16534A had another good one, same model, and took pictures of the board (for the U509 circuit) and sure enough, there's two SMD caps in his picture that aren't in mine! And they're right in the spot where the pads are. I just need to find the value now for both of those. Any idea how I can figure this out? Thanks! |
gwerwfe 发表于 2018-10-23 11:42 抱歉。 那个董事会至少有15年的历史,而且机构记忆早已不复存在...... Al 以上来自于谷歌翻译 以下为原文 Sorry. That board is, at least, 15 years old, and that institutional memory is long gone... Al |
谢谢Al。 我以前很怕那个。 希望我能找到一个拥有相同电路板的人,他们愿意拉上这两个电容并测量电容,这样我就可以尝试找到合适的替代品。 我很感激帮助。 以上来自于谷歌翻译 以下为原文 Thanks Al. I was afraid of that. Hopefully I can find someone who has the same board that's willing to pull those two caps and measure the capacitance so I can try and find a proper replacement. I appreciate the help. |
只有小组成员才能发言,加入小组>>
250 浏览 0 评论
1863 浏览 0 评论
2753 浏览 1 评论
2656 浏览 1 评论
2477 浏览 5 评论
1863浏览 0评论
432浏览 0评论
261浏览 0评论
/9
GMT+8, 2025-12-12 09:46 , Processed in 0.827872 second(s), Total 80, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5102
