电子发烧友论坛|
你好会员
我有一个关于计时器/计数器组件的计数输入的问题。 Q1。请告诉我如何计算计数输入设置为禁用。我认为计数器将改变它的计数在每一个输入时钟边缘。 在数据表中描述如下:“如果该输入被配置为对电平敏感,计数器将改变其在每个预缩放时钟边沿上的计数。” 如果是这样,在级别设置中,计数值的变化将不依赖于计数输入。这种识别正确吗?如果它不正确,请告诉我计数输入如何影响水平设置中的计数变化。 最好的问候 以上来自于百度翻译 以下为原文 Hello Members I have a question about the Count Input of the Timer / Counter component. Q1. Please tell me how to count when Count Input is set to Disable. I think the counter will change its count on every input clock edge. Q2.It is described in the data sheet as follows "if this input is configured for level sensitive, the counter will change its count on each pre-scaled clock edge." If so, at the level setting, the change in count value will not depend on count input. Is this recognition correct? If it is incorrect, please tell me how the count input influences the change of count at the level setting. Best Regards |
1个回答
你好,
Q1。请告诉我如何计算计数输入设置为禁用。我认为计数器将改变它的计数在每一个输入时钟边缘。 是的,这是正确的。 在数据表中描述如下:“如果该输入被配置为对电平敏感,计数器将改变其在每个预缩放时钟边沿上的计数。” 如果是这样,在级别设置中,计数值的变化将不依赖于计数输入。这种识别正确吗?如果它不正确,请告诉我计数输入如何影响水平设置中的计数变化。 这是正确的。但是只有当计数输入是活动的(高)时,这才适用。如果是低计数,则不会根据时钟输入增加。 谢谢, 希马 以上来自于百度翻译 以下为原文 Hello, Q1. Please tell me how to count when Count Input is set to Disable. I think the counter will change its count on every input clock edge. Yes it is correct. Q2.It is described in the data sheet as follows "if this input is configured for level sensitive, the counter will change its count on each pre-scaled clock edge." If so, at the level setting, the change in count value will not depend on count input. Is this recognition correct? If it is incorrect, please tell me how the count input influences the change of count at the level setting. This is correct. But this will apply good only when the count input is active (high). If it is low count would not increment based on the clock input. Thanks, Hima |
只有小组成员才能发言,加入小组>>
786个成员聚集在这个小组
加入小组cyUSB3014一直显示2.1,不能到3.0情况,谁遇到过
7070 浏览 0 评论
2474 浏览 1 评论
2165 浏览 1 评论
4030 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
2073 浏览 6 评论
CY8C4025LQI在程序中调用函数,通过示波器观察SCL引脚波形,无法将pin0.4(SCL)下拉是什么原因导致?
7566浏览 2评论
CYUSB3065焊接到USB3.0 TYPE-B口的焊接触点就无法使用是什么原因导致的?
6114浏览 2评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
742浏览 2评论
709浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
7961浏览 2评论
/9
GMT+8, 2025-12-1 15:51 , Processed in 0.559781 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
486
