我有几个8594E分析仪在500MHz频率下具有30kHz偏移的噪声边带测试失败。
规格为-75dBc。 这些单位通常测量约-74.7dBc。 我尝试过E8257D-UNX,E4438C-UNJ,9640A-LPNX和许多其他发电机。 在大约20个单元中,至少有8个单元未通过此测试。 是否有任何规格变更? 我已经在不同的位置和不同的长凳上测试了它们但它们仍然失败了。 接下来我该怎么办? 以上来自于谷歌翻译 以下为原文 I have several 8594E analyzers failing the Noise Sideband test at 500MHz with 30kHz offsets. The specification is -75dBc. The units are typically measuring around -74.7dBc. I have tried the E8257D-UNX, E4438C-UNJ, 9640A-LPNX, and a host of other generators. Out of about 20 units, at least 8 have failed this test. Has there been any specification changes? I have tested them at different locations and different benches but they still fail. What should I look for next? |
1个回答
原始性能测试写得不正确。
在进行此测试时,OEM频率为1 GHz,设置显示在书中并且没有信号应用,您将看到噪声基底从-75到-77 db从满量程下降。 这是设备的对数转换器本底噪声,对于整个系列而言是正常的。 测试应该以这种方式进行,就像设置和设置功率一样,使标记等于0 dBm。 然后将您的量程设置为1 KHz / 1 KHz RBW滤波器。 根据本书输入上下偏移量(10K,20K,30K和130K)。 将分析仪上的参考电平设置为-30 dBm。 进行测量时,您希望实际噪声基底比您尝试测量的最小误差至少低20 dB。 当本底噪声接近您所需的测量值时,误差会显着增加。 当您以这种方式测试设备时,您将看到设备实际通过所有偏移至少10 dB或更多。 这是正确测试所需的方法,但由于产品已过时,是德科技不会提供书面更正程序。 以上来自于谷歌翻译 以下为原文 The original performance test was written incorrectly. When doing this test, OEM frequency is 1 GHz, with the set up they show in the book and no signal applied you will see your noise floor bounce around from -75 to -77 db down from full scale. This is the log converter noise floor for the unit and is normal for the entire series. The test should be performed this way, as you would set up and set the power so the marker to equals 0 dBm. Then set your span to 1 KHz/ 1 KHz RBW filter. Enter in the upper and lower offsets (10K,20K,30K and 130K) as per the book. Set your reference level on the analyzer to -30 dBm. When doing measurements you want the actual noise floor to be at least 20 dB lower than what you are trying to measure for minimum error. As the noise floor is closer to your desired measurement the error increases significantly. When you test the unit this way you will see the unit actually passes all offsets by at least 10 dB or more. This is the way it should have been done for proper correct testing, but since the product is obsolete, Keysight will not provide a written corrected procedure. |
只有小组成员才能发言,加入小组>>
1221 浏览 0 评论
2346 浏览 1 评论
2155 浏览 1 评论
2021 浏览 5 评论
2900 浏览 3 评论
961浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
697浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
797浏览 0评论
1221浏览 0评论
GMT+8, 2024-11-22 05:29 , Processed in 1.217590 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
