电子发烧友论坛|
你好。
我拥有一台带有TG(跟踪发生器)的8594E,它不能工作(显示器坏了),另一台8594E工作得很好,但没有TG。 所以我想把TG部件从非工作单元转移到好工作单元。 我已阅读安捷伦文档,必须在工厂安装TG选件,用户无法升级。 所以我想在分析仪内组装TG时必然会有一些问题。 有没有人试图将TG板/模块转移到8594E或类似的? 这有多容易/困难? 问候。 路易斯。 以上来自于谷歌翻译 以下为原文 Hi. I own an 8594E with TG(tracking generator) which is not working (broken display) and another 8594E which works nicely but which does not have TG. So i thought to trasplant the TG part from the non working unit to the good one. I have read on Agilent documentation that the TG option must be installed on factory and cannot be upgraded by the user. So I guess there must be something involved in assembling the TG inside the analyzer. Has anyone tried to trasplant a TG board/module to a 8594E or similar ? How easy/difficult is it? Regards. luis. |
1个回答
嗨Luis - 跟踪发生器升级非常复杂,只需要工厂升级,选项K10。
将跟踪发生器从一台仪器移植到另一台仪器应该比升级更容易,因为大多数部件都放在一起,您将看到一切都适合您损坏的仪器。 我强烈建议您在查看9x服务指南的同时进行移植,您可以在a.com上找到该指南。 搜索8594E,然后在技术支持部分查看手册。 遗憾的是,没有安装说明,因此查看服务指南真的会有所帮助。 移植速度慢,运气好。 问候 - 以上来自于谷歌翻译 以下为原文 Hi Luis - The tracking generator upgrade was quite involved and required a factory only upgrade, option K10. Transplanting the tracking generator from one instrument to another should be easier than an upgrade since most of the parts are put together and you will see how everything fits in your broken instrument. I would highly recommend doing the transplant in conjunction with looking at the 9x service guide, which you can find at a.com; search on 8594E and then view the manual in the Technical Support section. Unfortunately, there are no installation instructions, so that is why viewing the service guide will really help. Go slow and best of luck with the transplant. Regards - |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 18:16 , Processed in 0.680875 second(s), Total 70, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1367
