电子发烧友论坛|
嗨,我有以下设置:8594E型频谱分析仪,8648B型信号发生器和85024A型高频概率仪。
当我将光谱分析仪连接到信号发生器通过探头尖端到N型适配器(1M-50欧姆终端器),高功率从5dBm及以上我得到不正确的结果(超过1 dB压缩点)什么是最大RF输入 (以dBm为单位)我可以按技术规格连接吗? 谢谢,加比 以上来自于谷歌翻译 以下为原文 Hi, I have the following setup : a spectrum analyzer Model 8594E, Signal Generator Model 8648B and High Frequency prob Model 85024A. When I connect the spectrun analyzer to the signal Generator Through Probe tip to type-N adapter (1M-50 ohms terminator) with High power from 5dBm and above I get incorrect results (over the 1 dB compression point) what is the Maximum RF Input (in dBm) I can connect by technical specifications? Thanks , Gabi |
1个回答
Hi Gabi - 带有11880A的85024A,50Ω连接器的有源探头提示并不意味着输入阻抗为50Ω,而输入阻抗为1MΩ。
在信号发生器测量中,输出阻抗为50Ω,因此与探头的1MΩ阻抗不匹配。 85024A探头的规格为1.5Vpeak,没有10:1分压器尖端。 1.5Vpeak = 1.605Vrms,即+ 13.52 dBm,可输入50Ω。 由于输入阻抗为1MΩ,因此源功率必须降低6 dB至+7.52 dBm,以避免损坏探头。 如果要使用10:1分频器,则最大值。 探头的输入电压为15Vpeak。 15Vpeak = 10.605Vrms,+ 33.52 dBm。 减去6 dB是+27.52 dBm是避免损坏探头的最大值。 问候 - 以上来自于谷歌翻译 以下为原文 Hi Gabi - The 85024A with the 11880A, Active Probe Tip to 50Ω connector does not imply that the input impedance is 50Ω, rather the input impedance is 1 MΩ. On your signal generator measurement, the output impedance is 50Ω, so there is a mis-match to the 1 MΩ impedance of the probe. The specifications for the 85024A probe is 1.5Vpeak without the 10:1 divider tip in place. 1.5Vpeak = 1.605Vrms, which is +13.52 dBm that would be delivered into 50Ω. Since the input impedance is 1MΩ, the source power would have to be reduced by 6 dB to +7.52 dBm to avoid damage to the probe. If the 10:1 divider were to be used, the max. input voltage to the probe is 15Vpeak. 15Vpeak = 10.605Vrms, which is +33.52 dBm. Subtracting 6 dB is +27.52 dBm is the maximum to avoid damage to the probe. Regards - |
只有小组成员才能发言,加入小组>>
1842 浏览 0 评论
2738 浏览 1 评论
2640 浏览 1 评论
2447 浏览 5 评论
3452 浏览 3 评论
1844浏览 0评论
416浏览 0评论
/9
GMT+8, 2025-12-1 19:43 , Processed in 0.540363 second(s), Total 42, Slave 35 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1590
