电子发烧友论坛|
皮克特2PLUS和皮克特3PLUS编程软件,以取代现有的皮卡2和皮卡3编程软件。皮克特2PLUS和皮克特3PLUS编程软件是巨大的更新,软件已经“支持”正式支持了许多,许多年。语法软件可以使用PACKIT 2和PICIT 3程序员来编程新的部件,如16F18855和18F24K42(以及所有相关的家庭部件-这些只是两个例子)。新软件有两个新的协议来支持这些新的部件,以及对ADDR的许多增强。使用其他版本的Windows时,ESS Windows 10的使用和访问控制问题。这个新的软件也改变了零件数据库来支持新零件加上许多新零件的添加…但是,我肯定会有部分丢失。修复和更改已经在WindowsXP、Windows 7和Windows 10(32和64位)上进行了测试。我正在寻找测试PkiT2PUS的人。这已经被一小群人测试过了,但是它需要一个更大的测试小组。如果您愿意测试-包括安装包,然后请给我一个个人信息。我可以分享下载URL和测试协议。肯定会有问题和问题-因此请求测试帮助。我将释放PikIt 3PLUS OnCEKIti2PLUS是在野外。
以上来自于百度翻译 以下为原文 PICKit 2Plus and PICKit 3Plus programming software to replace the existing PICKit 2 and PICKit 3 programming software. PICKit 2Plus and PICKit 3Plus programming software is huge update to the software that has been 'out of support' formal support for many, many years. PICKit 2Plus and PICKit 3Plus programming software enables the use of the PICKit 2 and PICKit 3 programmers to program the newer parts like the 16f18855 and the 18f24k42 (and all the related family parts -these are just two examples). The new software has two new protocols to support these newer parts, and, many enhancements to address Windows 10 usage and access control issues when using other versions of Windows. This new software also has a change to the parts database to support the new parts plus the addition of many new parts... but, I sure some parts will be missing. The fixes and changes have been tested on Windows XP, Windows 7 and Windows 10 (32 and 64 bit). I am looking for people to test PICKit 2Plus. This has been tested by a small set of folks but it needs a little bigger group of testers. If you are willing to test - there is installation package included then please send me a personal message. I can share the download URL and the testing protocol. There are bound to be issues and problems - hence the ask for test help. I will release PICKit 3Plus once PICKit 2Plus is out in the wild. Attached Image(s) |
19个回答
修改后的用户界面显示新的部件之一,使用新实现的协议,以及其他用户界面更改,例如部件族编号、部件唯一ID和硅修订。修订后的帮助显示了支持的全部部分。
以上来自于百度翻译 以下为原文 The revised user interface showing one of the newer parts, using the newly implemented protocols, and other user interface changes such the part family number, part Unique ID and silicon revisions. The revised Help shows the full parts supported. |
WindowsSputsPikI2PPLUS现在包括一个修订的安装程序,包括更新的Windows XP支持的部分数据库.NET。将PigIt 2PLUS INI文件更改为现在将INI文件保存到用户位置,而不是安装文件夹,它应该解决许多安装和使用能力问题。在Windows XP、7和10上对PACKIT2PLUS进行了测试,在32和64个操作系统变种上进行测试。
以上来自于百度翻译 以下为原文 Windows Support PICKit 2Plus now includes a revised installer including the updated parts database, .NET of Windows XP support. Changes the PICKit 2Plus ini file to now save the ini file to user location rather then the installation folder which should resolve many of the installation and use ability issues. PICKit 2Plus has been tested on Windows XP, 7 and 10 on 32 and 64 operating system variants. |
嗨,我有好的旧皮卡2可以测试,你可以分享PLUS编程软件链接吗?将计划一些18F2*18F4*MCU。干杯,
以上来自于百度翻译 以下为原文 Hi, I have the good old PICkit 2 can test, could you share the plus programming software link? Will program some 18F2* 18F4* mcus. Cheers, |
嗨,图像非常类似于我的主窗口的修改版本。2013,我开始通过添加新的部件来改进软件。当固件修改时,CIPIT2+被改名为PICKIT 2.5。抱歉,论坛的语言是匈牙利语。
以上来自于百度翻译 以下为原文 Hi, the image is very similar to my main window of mine modified version. In 2013 I started to improve the software by adding new parts. The PICkit2 + was renamed to PICkit 2.5 when firmware was modified. Sorry, the language of forum is hungarian. |
谢谢。我读了那个论坛帖子,但是找不到下载链接,或者是PikI2PPLUS还是PICIT 2.5?它已经发布测试了吗?
以上来自于百度翻译 以下为原文 Thanks. I had a read of that forum thread but can't found a download link for either PICkit 2Plus or PICkit 2.5? Has it been released to test yet? |
暴跳如雷。对。给我一个下午。其他人也有。-)
以上来自于百度翻译 以下为原文 @Rampage. Yes. Send me a PM. Others have. :-) |
ScasisYour的工作很好。谷歌翻译很棒!
以上来自于百度翻译 以下为原文 @Scasis Your work was very good. Google translate is excellent! |
最新零件清单可在这里找到。每天添加部分。http://GITHUB.COM/ANOBIU…/PICTITPLUESDEVICIC.TXT
以上来自于百度翻译 以下为原文 Latest parts list can be found here. Adding parts daily. https://github.com/Anobiu.../PICKitPlusDevices.txt |
NeX.PikPiPress现在发布了。我们每天都提供给人们。
以上来自于百度翻译 以下为原文 News. PICKItPlus is now on general release. We are providing to people daily. See http://gcbasic.sourceforge.net/pickitPlus for information on how to obtain. |
PixIt Plus有三个变体:一个用于PigIT2程序员的Windows GUI应用程序,另一个用于PICTIT3程序员的Windows GUI应用程序,以及一个用于PICTIT2和PICTIT3程序员的命令行实用程序。我们已经更新、修改和添加了新的协议来支持。微芯片8位部件自微芯片丢弃支持,2009和2012用于PK2和PK3 GUI应用,并且非常重要的是支持较新范围的微芯片部件(因此新协议)。更新了零件库,帮助等,所以我们测试并得到了更多的人测试-结果非常好。我们没有分享申请太远,因为我们有一个“去市场”计划。看下一段。然后,我们开始了“去市场”的计划。这个计划相对简单。选择之一是要求微芯片在微芯片的旗帜下进行开发。这对每个人来说都是比较容易的选择。Microchip将获得工作的信任,商业安排将覆盖支持成本,Microchip将“证书签署”PickPlus应用程序(因为这不便宜),然后软件将释放给大家作为免费软件。就像过去一样。在与微芯片8位副总裁合作之后,他得到的回应是微芯片程序员的一个惊喜。他们(Microchip程序员师)似乎不太兴奋……(不认为他们愿意延长旧的选择。所有的产品都是……是的,一个支架在反应中丢失了。-那么,我们必须进入“去市场”计划的下一步。寻找应用程序包装的资金,整理许可,并在一个更复杂的模式中发布一个新的包。总结。我们有一个非常好的编程套件,为PACKIT2和PICTIT3程序员,这将延长你的程序员/投资的生命。不需要购买一个新程序员只是为了编程一部分,并且所有的旧部件都使用PkIdPlus。但是,我们需要捐款。我们不是一个慈善机构,需要付出真正的代价来发布一个签名和维护一个像PikPlus这样的应用程序。希望这有帮助。埃文。
以上来自于百度翻译 以下为原文 The whole story. PICKit Plus comes in three variants - a Windows GUI application for the PICKIT2 programmer, another Windows GUI application for the PICKIT3 programmer and a command line utility for both the PICKIT2 and PICKIT3 programmers. We have updated, revised and added new protocols to support the Microchip 8 bit parts released since Microchip dropped support, in 2009 and 2012 for PK2 and PK3 GUI applications, and, very importantly support for the newer range of Microchip parts (hence the new protocols). Updated the parts database, help etc. So, we tested and got folks to test even more - results were very good. We did not not share the application too far as we had a 'Go To Market' plan.... see next paragraph. Then, we started the 'Go To Market' plan. The plan was relatively simple. Option One was to ask Microchip to take the development back under the banner of Microchip. This is the easier option for everyone. Microchip would get the credit for work, a commercial arrangement would cover the support costs, Microchip would 'certificate sign' the PICKit Plus applications (as this is not cheap) and then the software would be released to you all as freeware. As it was in the past. Well after working with the Microchip 8-Bit Division Vice President...the response he got was a bit of a surprise from the Microchip Programmer Division. Quote They (Microchip Programmer Division) did not seem very excited… (do not think they would like to prolong the old PICKiT products at all….. Yes, a brace was missing in the response. :-) So, we have to go to the next step in the 'Go To Market' plan. Find the funding for the application packaging, sort out licensing, and release a new package in a more complex manner. Summary. We have a very good programming suite for the PICKIT2 and PICKIT3 programmers that will extend the life of your programmer/investment. No need to buy a new programmer just to program a part, and, all you old parts work with PICKIT Plus. But, we need donations. We are not a charity and there are real costs that have to borne to release a signed and maintain an application like PICKit Plus. Hope this helps. Evan |
也许这可以成为Kickstarter或类似站点的一个项目,或者在HTTP://www-EndodCudioSuthC.com上发布,或者发布在HTTPS://www. MyCHIP.COM/FUMMS/F56ASPX上。
以上来自于百度翻译 以下为原文 Maybe this could become a project on kickstarter or some similar site Or sold on http://www.embeddedcodesource.com/ Or posted in https://www.microchip.com/forums/f56.aspx |
我们不希望这样做一个巨大的项目。我们有一个计划“PHutt”,谢谢你的URL,这些都很好。非常感激。我明天再调查埃文
以上来自于百度翻译 以下为原文 We are not wanting/wishing to make a huge project of this. We had a plan that went 'phutt'. Thank you for the URLs - these are good. Most grateful. I will investigate tomorrow. Evan |
我应该提到…我们目前正在修复一个长期存在的错误,其中一些设备松开带隙配置,我们正在更新支持的设备。Re BandGap应该在接下来的几周内被修复,然后作为我们的发布周期的一部分被释放。EXP/PICTIT3PLUS/文件/ RealMex.MalkDe/下载
以上来自于百度翻译 以下为原文 I should have mentioned... we are currently fixing a long standing bug where some devices loose the BANDGAP configuration and we are updating the device supported. Re BandGap this should be fixed in the next few weeks and then released as part of our release cycle. For latest list of devices download https://sourceforge.net/projects/pickit3plus/files/readmetxt.markdown/download |
下载的实际情况在哪里?我所能找到的只是设备文件。我对微芯片上的人并不感到惊讶,所以卢克以任何方式来帮助他们;他们为修复正在出售的新硬件而谋生,开发下一个硬件;他们把目光投向地平线,而不是向后看。SiON杀死旧皮卡是基于技术问题(其中有许多地方缺少一个内存空间)或纯粹的商业利益(移动产品)是任何人猜测的。皮卡2对Microchip来说是一个真正的惊喜。第一次发布是一个“噱头”,但起飞超出了他们最疯狂的梦想,并赢得了一个地方,在数百万的爱好者和专业人员的心和实验室只是因为它只是工作。PK3是一个返工,基于“越多越好”(如你所知,它甚至使用相同的设备文件……)从来没有很好的工作,也没有相同的后续。现在这也被抛弃了,有利于PICTIT4;它有一个相当便宜的小“狗”所要求的所有特征。这也超过了它公平的问题;正如我发现的……我看可能有。这个软件的一个小市场,因为人们喜欢使用他们喜欢的东西。我会为一个增加PICKits的特性和支持的应用付费,我讨厌“跳过”刚刚过时的东西。(但我还没有原谅Microchip让PicStus Plus过时了!)如果你要钱/捐款,它应该覆盖它的“真实世界”的成本;或者释放它作为开源软件,看看它是否幸存在野生的:无论哪种方式;保持良好的工作!
以上来自于百度翻译 以下为原文 where are the actual aplications to download? all i can find is the device files. i'm not exactly surprised the people at microchip are so luke-warm about helping in any way;they make their living trying to fix the new hardware being being sold,and develop the next ones; they have their eyes on the horizon not looking backwards.Whether the decision to kill off the old pickits was based on technical problems (of which there where many,lack of internal memory space for one) or purely commercial interests (shifting products) is anyones guess. The PICKit 2 was a real surprise to microchip; developed in-house by an enginer who's since left,it was first released as a bit of a 'gimmick' but took off beyond their wildest dreams,and earned a place in the hearts and labs of millions of hobbyists and pro's simply because it just worked.The PK3 was a rework,based on 'the more the merrier' (as you know,it even used the same device file...) but never quite worked as well,and doesn't have the same following.Now this has been dumped as well, in favour of the PICKit4; which has all the features people have asked for in one fairly cheap little 'dongle'.This also has more than its fair share of problems; as i've found out...i see there may be a small market for this software,as people love to keep using things they are comfortable with.I would pay for an application that added features and support to the PICKits; i hate to 'skip' things that just get out-dated. (but then i haven't forgiven microchip for making the Picstart Plus obsolete!) if you asked for money/donations it should cover its 'real-world' costs; or release it as FOSS and see if it survives in the wildwink: either way; keep up the good work! |
为什么不为PICTIT2和PICTIT3做一个GUI应用程序来自动检测这两个家伙当前连接的是哪一个?
以上来自于百度翻译 以下为原文 Why not make a single GUI application for both PICKIT2 and PICKIT3 which automatically detects which of the two guys is currently connected? |
很多问题。查看HTTP://GCBASIC.SooSurf.G.NET/CHIPITPLUS来获取如何获得信息。我已经和开发人员在一定程度上谈过了,并且开发程序的描述是我所听到的相同的故事。三个应用程序的Rational相对简单。PK2程序员有能力,这些应用程序需要特定的应用程序。PK3程序员有能力,这些应用需要特定的应用程序。我们已经从地面上重新编写了命令行实用程序。因此,为PK2和PK3重新编写GUI以暴露不同的能力将是1000个小时。我们已经花费了大量的时间来清理错误和新的协议——因此,三个应用程序正在进行中。我们即将搬到捐赠箱,以缓解捐赠过程。埃文
以上来自于百度翻译 以下为原文 Lots of questions. See http://gcbasic.sourceforge.net/pickitPlus for information on how to obtain. I have spoken with the developers at some length, and, the description of the development program is the same story I have heard. The rational for the three applications is relatively simple. PK2 programmer has capabilities and the specific application is needed for those capabilities. PK3 programmer has capabilities and the specific application is needed for those capabilities. We have totally re-written the command line utility from the ground-up. So, to rewrite the GUI for the PK2 and the PK3 to expose the different capabilities would be a few 1000 hours. We have already spent a huge number of hours sorting out the bugs and the new protocols - so, three applications going forward. We are covering costs with the donation program. We are moving to DONATIONBOX soon to ease the donation process. Evan |
UpDebug支持设备:我们已经更新了部件数据库以增加更多的部件并提高质量。查看最新的部分数据库HTTPS://SurfFur.NET/PrimeS/PcPIT3PLUS。请记住,当使用PACKIT Plus软件时,新的部件仅被支持,因为PACKIT Plus软件具有所需的新协议。软件:我们正在为12F675等部件添加带隙的支持。这很快就可以买到了。Bandgap是Microchip软件中的一个开放式bug,意味着12F675这样的部件被编程为带隙不正确的容差设置。
以上来自于百度翻译 以下为原文 Update Support Devices: We have updated the parts database to add more parts and to improve quality. See https://sourceforge.net/projects/pickit3plus/ for the latest parts database. Remember the newer parts are only supported when you use PICKit Plus software as the PICKit Plus software has the new protocols needed. Software: We are adding support for 12f675 etc parts for Bandgap. This will be available very soon. Bandgap was an open bug in the Microchip software and meant the parts like the 12f675 where being programmed with the incorrect tolerance setting for Bandgap. |
坦率地说,一个非常好的通用ICSP程序员硬件不应该包含任何MCU,因为现代FT32H/FT223 2H芯片在主机端(PC)侧都有这个-HS USB和MCU侧的UART/FIFO/MPSSE。PIC8/16/32/AVR/山姆/ST单片机使用的任何原始编程接口都可以通过正确处理和高效地使用FTXXXH设备来进行仿真,而调试是完全不必要的。你需要的只是一个聪明的程序员,他应该编写GUI应用程序而不使用任何庞大的框架。
以上来自于百度翻译 以下为原文 Frankly speaking, a really good universal ICSP programmer hardware should NOT contain any MCU because the modern FT232H/FT2232H chips have all the necessary for this - HS USB at host (PC) side and UART/FIFO/MPSSE at MCU side. Any of the primitive programming interface the PIC8/16/32/AVR/SAM/ST MCU are using can be easily emulated by properly handling and efficiently using the FTxxxxH facilities while debugging is not necessary at all. All you need is just ONE smart programmer guy who should write the GUI application without using any bulky frameworks. |
只有小组成员才能发言,加入小组>>
MPLAB X IDE V6.25版本怎么对bootloader和应用程序进行烧录
473 浏览 0 评论
5793 浏览 9 评论
2334 浏览 8 评论
2224 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
3530 浏览 3 评论
1124浏览 1评论
有偿咨询,关于MPLAB X IPE烧录PIC32MX所遇到的问题
1095浏览 1评论
我是Microchip 的代理商,有PIC16F1829T-I/SS 技术问题可以咨询我,微信:A-chip-Ti
873浏览 1评论
475浏览 0评论
/9
GMT+8, 2025-12-2 03:51 , Processed in 1.418111 second(s), Total 108, Slave 91 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2478
