电子发烧友论坛|
9 个讨论
你好,程序进入了exit.c文件的 void exit(int status) [ /*-------------------------------------------------------------------*/ /* MUST LOCK WHEN ACCESSING GLOBALS, like __TI_dtors_ptr, */ /* __TI_cleanup_ptr */ /*-------------------------------------------------------------------*/ _lock(); /*-------------------------------------------------------------------*/ /* BOTH ATEXIT FUNCTIONS AND STATIC OBJECT DESTRUCTORS ARE */ /* REGISTERED IN A LINK LIST POINTED BY __TI_dtors_ptr, NOW WALK */ /* THROUGH THIS LIST TO CALL THEM. */ /*-------------------------------------------------------------------*/ if (__TI_dtors_ptr) (*__TI_dtors_ptr)(status); #if defined(_C_IN_NS) /*-------------------------------------------------------------------*/ /* _C_IN_NS IS A FLAG WE SET ONLY IN DINKUMWARE HEADERS. SO US IT TO */ /* TELL IF IT IS IN DINKUMWARE. */ /* FOR DINKUMWARE LIBRARY, CALL CLOSEALL() TO CLOSE ALL IO STREAMS. */ /* CLOSEALL() is a DINKUMWARE FUNCTION DEFINED IN FCLOSE.C TO CLOSE */ /* ALL OPENED IOSTREAMS. */ /*-------------------------------------------------------------------*/ closeall(); #else /*-------------------------------------------------------------------*/ /* IF FILES ARE POSSIBLY OPEN, __TI_cleanup_ptr() WILL BE SETUP TO */ /* CLOSE THEM. */ /*-------------------------------------------------------------------*/ if (__TI_cleanup_ptr) (*__TI_cleanup_ptr)(); #endif abort(); ] /****************************************************************************/ /* ABORT - ABNORMAL PROGRAM TERMINATION. CURRENTLY JUST HALTS EXECUTION. */ /****************************************************************************/ void abort(void) [ /*-------------------------------------------------------------------*/ /* SET C$$EXIT LABEL SO THE DEBUGGER KNOWS WHEN THE C++ PROGRAM HAS */ /* COMPLETED. THIS CAN BE REMOVED IF THE DEBUGGER IS NOT USED. */ /*-------------------------------------------------------------------*/ __asm(" .global C$$EXIT"); __asm("C$$EXIT: nop"); for (;;); /* SPINS FOREVER */ ] 这部分,软件断点说的是这部分吗?是直接将这个文件给屏蔽掉吗? |
您好!首先出现一个问题,在我下载了几次API的程序过后,我的板子不知道怎么就无法在向FLASH里面写程序了,出现一些提示C28xx: Flash Programmer: Error encountered when writing to flash memory C28xx: GEL: File: C:UsersAdministratorDesktop28035_work_bookDebug28035.out: Load failed但是可以在RAM环境下在线调试。 而且我换为别的板子调试的时候,在程序中也加入了while(1)死循环,把asm(" ESTOP0");都给屏蔽掉了,但是还是出现前面图片的那种情况,我感觉也是进入了BOOTROM,但是想不出怎么解决了,求救!!!!!!!!!!! |
ldd1211_ 发表于 2018-10-3 13:09 第一个问题你试试连上板子,通过on-chip flash执行Depletion Recovery,然后再重新erase。 第二个问题你先执行restart,然后再全速运行。 |
只有小组成员才能发言,加入小组>>
576 浏览 0 评论
1636 浏览 0 评论
2070 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1527 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1365 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1779浏览 29评论
2806浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1737浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1651浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1664浏览 13评论
/9
GMT+8, 2025-12-8 16:37 , Processed in 1.033512 second(s), Total 60, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1997
