扫一扫,分享给好友
我正在尝试在Windows 10 VM上为我的p40安装最新的Windows驱动程序(391.20),在VMWare ESXi6.5和GRID 5.2中运行。
安装驱动程序告诉我它找不到兼容的硬件。 我能够安装的唯一版本是386.09。 有谁知道是否有设置可以让我在我的VDI上安装391.29? 谢谢, -Ryan 以上来自于谷歌翻译 以下为原文 I'm trying to install the latest Windows Driver (391.20) for my p40 on a Windows 10 VM, running in VMWare ESXi6.5 and GRID 5.2. Installing the driver tells me that it can't find compatible hardware. The only version that I am able to install is 386.09. Does anyone know if there is a setting that would let me install 391.29 on my VDI? Thanks, -Ryan |
1个回答
vGPU使用中介(半虚拟化)驱动程序,该驱动程序需要在来宾和主机之间使用特定版本的NVidia专有协议(VGX)。
您需要兼容的VGX版本和支持VGX协议的增强驱动程序。 NVidia仅支持在GRID包中发布的组合(例如,对于GRID 5.2 - 384.111主机驱动程序和386.09 win guest驱动程序),但有时它也适用于具有兼容VGX协议的其他win客户驱动程序(由于“统一驱动程序”)但仅在 相同的“分支发布”行(参见:http://www.nvidia.com/object/quadro-branch-history-table.html)。 GRID 6.0几天前发布,带有390.42主机驱动程序和391.03 win客户驱动程序的驱动程序(请参阅https://docs.nvidia.com/grid/index.html)。 您应该升级到GRID 6.0。 以上来自于谷歌翻译 以下为原文 The vGPU uses mediated (paravirtualized) driver that needs specific version of NVidia proprietary protocol (VGX) between guest and host. You need the compatible VGX version and enhanced drivers with VGX protocol support. NVidia supports only combination that is released in GRID package (eg. for GRID 5.2 - 384.111 host driver and 386.09 win guest driver) but sometimes it works also other win guest driver with compatible VGX protocol (due to "unified driver") but only in the same "branch release" line (see: http://www.nvidia.com/object/quadro-branch-history-table.html). GRID 6.0 was released few days ago with driver with 390.42 host driver and 391.03 win guest driver (see https://docs.nvidia.com/grid/index.html). You should upgrade to GRID 6.0. |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3819 浏览 4 评论
/9
GMT+8, 2025-12-2 03:40 , Processed in 7.447326 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3910
