电子发烧友论坛|
你好
我正在运行以下实验室设置: 2个HPDL380 G9主机,每个主机带有1个K1 GRID卡 Horizon 7.0.2 Enterprise vCenter 6.5 4602587 每台主机上的VMware ESXi 6.5.0 4564106(两者上的Enterprise Plus许可证) 我已经安装了最新的4.1 GRID驱动程序集 - 包括ESXi VIB(nvidia-smi在两台主机上报告都正常)。 我根据Horizon 6.1部署指南创建了K120Q和K160Q VGPU模板Win7 x64 VM但是当我尝试选择模板时,我收到以下消息: 'NVIDIA GRID VGPU支持与桌面设置不匹配' 我无法继续使用VGPU池。 我可以通过此Horizon安装创建启用非GRID的池和桌面。 我可以使用View客户端连接到用于模板的基本映像,并可以验证Nvidia控制面板中显示的正确配置文件。 在我看来这是一个许可问题? 我查看了发行说明,可以看到ESXi 6.5和vCenter不是K1支持的验证平台(运行到ESXi 6.0u2和vCenter 6.0),但Horizon 7.0.2已经过验证。 这只是一个没有验证更高版本的管理程序的情况吗? 我曾经多次见过这个问题,一次是在这个论坛上,但没有答案。 有没有人对此错误有任何见解? 谢谢 以上来自于谷歌翻译 以下为原文 Hi I am running the following lab set up: 2 x HPDL380 G9 hosts each with 1 x K1 GRID card Horizon 7.0.2 Enterprise vCenter 6.5 4602587 VMware ESXi 6.5.0 4564106 on each host (Enterprise Plus licenses on both) I've installed the latest 4.1 GRID driver set - including the ESXi VIB (nvidia-smi reporting all ok on both hosts). I have created a K120Q and K160Q VGPU template Win7 x64 VM as per the Horizon 6.1 deployment guide however when I try to select the template I get the following message: ‘NVIDIA GRID VGPU support does not match desktop setting’ I can't then proceed with the VGPU pool. I can create non-GRID enabled pools and desktops via this Horizon installation. I can connect to the base image used for the template using a View client and can verify that the correct profile shows in the Nvidia Control Panel. This appears to me as a licensing issue? I've checked over the release notes and can see that ESXi 6.5 nor vCenter is not a validated platform for K1 support (runs up to ESXi 6.0u2 and vCenter 6.0) but Horizon 7.0.2 is validated. Is this simply a case of no validation for the later versions of hypervisor? I've seen this question a couple of times, once on this forum but no answers. Has anyone any insight into this error? Thanks |
5个回答
你好
可能是驱动程序问题,因为Kepler系列GPU没有GRID 4.1。 您可以从此处下载正确的驱动程序:http://www.nvidia.com/Download/index.aspx?lang = en-us 将这些详细信息用于您的系统: 产品类型= GRID 产品系列= NVIDIA GRID vGPU 产品= GRID K1 操作系统= VMware vSphere ESXi 6.5 您需要更改ESXi主机驱动程序和Windows驱动程序以确保兼容性。 基于开普勒的GPU(K1 / K2)不需要任何许可。 他们也没有任何NVIDIA支持。 Maxwell GPU(M6 / M60 / M10)确实需要许可,您可以在顶部购买SUMS以获得NVIDIA支持。 问候 以上来自于谷歌翻译 以下为原文 Hi Could be a driver issue, as there is no GRID 4.1 for the Kepler series GPUs. You can download the correct drivers from here: http://www.nvidia.com/Download/index.aspx?lang=en-us Use these details for your system: Product Type = GRID Product Series = NVIDIA GRID vGPU Product = GRID K1 Operating System = VMware vSphere ESXi 6.5 You'll need to change out the ESXi host driver and Windows driver to ensure compatibility. Kepler based GPUs (K1 / K2) don't require any licensing. They also do not come with any NVIDIA support. Maxwell GPUs (M6 / M60 / M10) do require licensing and you can purchase SUMS on top for NVIDIA support. Regards |
你好
试试Horizon 7.0.3 一位VMware工程师告诉我,这个问题是在ESXi 6.5 beta测试中发现的,并以7.0.3解决 问候 以上来自于谷歌翻译 以下为原文 Hi Try Horizon 7.0.3 An VMware engineer told me the issue was found at ESXi 6.5 beta test and resolved with 7.0.3 Regards |
好的 - 谢谢回复。
4.1驱动程序版本的发行文档中详细介绍了K1 / K2支持 - 我假设VIB和Windows guest虚拟机可以在M和K GRID硬件上运行。 我可以尝试这两个建议并报告回来 以上来自于谷歌翻译 以下为原文 Ok great - thanks for the replies. K1/K2 support is detailed in the release documentation for the 4.1 driver releases - i'd assumed that the VIB and Windows guest would work on both M and K GRID hardware. I can try both of these suggestions and report back |
确定 - 从NVidia网站下载了K1 / K2 GRID驱动程序 - 卸载了4.1 VIB并将K1 VIB安装到两个ESXi主机上。
此外,在模板上,我卸载了4.1 Windows客户机驱动程序并安装了K1 Windows客户机驱动程序(实际上是同一个文件)。 试图像以前一样创建vGPU池 - 没有骰子。 相同的错误,模板无法选择 将Horizon View Connection服务器更新到7.0.3并尝试创建vGPU池 - 成功! 现有的配置可能只适用于7.0.3的更新,但我可以将其保留一天。 谢谢大家 以上来自于谷歌翻译 以下为原文 Ok - downloaded the K1/K2 GRID drivers from the NVidia website - uninstalled the 4.1 VIB and installed the K1 VIB onto both ESXi hosts. Also, on the template I uninstalled the 4.1 Windows guest driver and installed the K1 Windows guest driver (which is actually the same file). Tried to create the vGPU pool as before - no dice. Same error and the template was unavailable for selection Updated both Horizon View Connection servers to 7.0.3 and tried to create the vGPU pool - success! It's likely that the existing config may have worked with just the update to 7.0.3 but I can leave that for another day. Thanks all |
太棒了,很高兴你把它整理好了!
我不知道Maxwell司机与Kepler兼容......每天都是上学日:-) 问候 以上来自于谷歌翻译 以下为原文 Great, glad you got it sorted! I wasn't aware that the Maxwell drivers were compatible with Kepler ... Every day's a school day :-) Regards |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
3396 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3818 浏览 4 评论
/9
GMT+8, 2025-12-1 18:50 , Processed in 0.589505 second(s), Total 51, Slave 44 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1374
